Load sites.
What can you tell me about the load sites, like Getloaded.com?
Are they all pretty much the same? Do they all have different freight (i.e. the load you're looking for might be on a different board than the one you're subscribed to)? Which one is the best? Are certain boards better than others for certain parts of the country? Are they pretty straight forward to get set up on and use? That's all I can think to ask right now but feel free to add any other useful info. Thanks |
Once you've got your load and destination worked out how do you figure out a backhaul?
another good one - i think - is truckersedge.net they have booklets at most truck stops and operate pretty much on the same model as internettruckstop.com they are geared towards a small operator - people with one or a couple of trucks. |
so the equipment listed on these sites, is that the equipment you're hooking up to or the equipment you need to take the load?
I think it means the equipment you need to take the load.
If they want you too hook up to their equipment i think it says power only . But i dont know for sure |
Most loadboards have the capability to search by area or type of freight. Most also have a credit service that can be purchased at additional cost. You may find some loads on some boards and not on others. You should find many of the same loads on most boards. And you may find more posted in one region on one board and the opposite on a different board. There are also brokers who have their own loadboards. If you are a member of OOIDA, you can subscribe to their load board www.mymembersedge.com at a reduced rate. It is a DAT board and is supposed to have the same loads posted as the DAT board you find in most truck stops. You can post your truck or search for loads. There are loadboards that are more specialized, such as for carhaulers. Most other boards do require that you have your authority or have permission from your carrier to subscribe.
How do you work out a backhaul?
There is no such thing as a backhaul. If you are looking for a reload to get you somewhere, you need to post your truck on some of the loadboards or start calling brokers. When you post your truck you should start to get calls. When things are slow you may not receive calls. In that case, you may need to relocate your equipment to an area where you can get a decent paying load. I typically stay out of the bad freight areas unless I receive enough going in to deadhead out. With time you should begin to develop relationships with some brokers. That can make it easier when it comes to getting better paying loads. If you are attempting to get back to a certain area it may be necessary to go to a different area and work your way back unless you want to do a lot of deadheading.
OKay, I guess what I am wondering is about a reload to get me back to where I started (relatively speaking)? On the load board I can put in where I am at , and it will show all of the freight within a given radius. What I don't see is a way to put in a destination radius and find all freight going there.
Does that make sense? |
Super 8,
I know what you are saying, are you looking for a starting point? Meaning, you want to know before you go to Place A, that there is freight coming out of there going back to Place A, right? If so, wouldn't you just put in the destination city first? Example, say you are based out of Kansas City, and you find freight going to Las Vegas, what you are asking is a way to find freight around Las Vegas, going back to Kansas City, before you take the load to Las Vegas in the first place? If that's the case, I would just run a search with Las Vegas as the origin and put within, 50 miles or whatever you are comfortable with, and see what comes out, you might not get KC specifically, but you might get something going to Wichita, Oklahoma City, Amarillo, Albquerque, and if you do, run another search with one of those, looking to get to KC etc, Seems that would be the way to do it. |
You may need to go somewhere else in order to get back to where you want to go. For instance, you may want to start in Houston, TX. You get a load going to Cleveland, OH. There isn't anything going back to Houston, so you get a load to New Orleans, LA. From there you get a load to La Porte, TX. That is just outside of Houston. You may not always be able to get a reload right back to where you came from or want to go. Occasionally, you might find something that is dedicated or semi-dedicated that will get you back to your starting point. Most load boards have starting and "desired destinations." I usually put about 150 mile radius on both ends. That is normally a decent radius. Sometimes you can get lucky and get exactly what you want. When you are in a down economy it can be more difficult to get the exact routing you want. It may also necessitate that you stay out longer to earn a decent living or to get back to your starting point.
The reload doesn't necessarily have to get me back home. It just needs to take me past home. For example, My first load could take me to Michigan. Then I could grab something bound for Wisconsin. On my way there I go practically right past my home. When I was a company driver, it seemed like they were always getting me more or less back into my area with my reloads. As an Owner Op, I won't have a dispatcher to rely upon to set this stuff up. I'll have to know how to do it myself. I'm not as concerned about where I'm going as I am about knowing I can get back. I'm trying to keep this a local as possible. I don't mind being gone a night or two, but being gone all the time is not going to work for my situation. I figure between Chicago, Detroit and Milwaukee, there has got to be enough freight running that I can keep busy and get past home. I'm just uncertain of how to do this using the load boards when you can't punch in a starting and destination radius and see all the freight going to and from those points. Obviously it's an inexperience issue on my part. I'm sure there's a simple way to work this out that I am not aware of. |
You can punch in a starting and ending destination with a radius search on most loadboards.
Hey Gman,
My other thread got closed, I presume because it was in the wrong area, didn't want to make another thread, Two quick questions on your previous posts there, A.) Is there a rate that you won't go below, or does that just depend on the circumstances (what the run is, who it's for, where it's going, equipment needed, etc?) B.) When you had your dispatch company, did you handle all the billing etc, I would think that would be apart of all the paperwork and service provided etc. Thanks, Sam |
I don't know what happened with the other thread. I do have a minimum rate that I will take a load. The minimum rate will vary according to where I will be going, what I am hauling and the availability of freight out of the area where I will deliver. I know it sounds vague, but that is the way that I do it. I have a minimum rate for over sized freight which is higher than if the load is legal. I know some people who only have one minimum rate that they won't haul below. Even when times have been so bad the last couple of years, I refused to haul a load for less than my cost of doing business and a profit. In fact, I parked my trucks at one point due to the cheap rates. If I can't make a profit hauling freight I would rather go broke sitting at home than hauling for free. There are those who will put anything on their truck just to keep moving whether that load is profitable or not. When I was dispatching sometimes I handled the billing and sometimes the carrier did their own. I always received and read over the contract with the broker or shipper, checked credit and handled all contact until the load was booked. I usually followed up when the load was delivered to let the broker or shipper know that the load had been successfully delivered. Basically, all the owner operator or carrier had to do was pick up and deliver the load, then deposit his check when it came in. |
ITS is the one that i use and guide myself to have any idea what rates are going on.I only use brokers that i know. If there is lots of loads out of one area, i know my strength of negotiating a superb rate.Thats how my best loads this year came,when in a matter of minutes of posting my truck i had over 10 voice mails from brokers desperate to find a truck.Rates from ranged from the low $2.50 a mile to $3.50 a mile.Really cant complain about that.When i post my truck and i get seldom calls then i know i have to call them and basically be at their mercy.Thats especially available from the east coast back to the west coast,since the freight base on the east coast isn't very strong like the other way around.
Have you ever used a dispatch service, or thought about using one? Just trying to get different opinions on it, to see if it is viable to start one, not looking to get rich or screw anyone out of it, just looking for something I can do that will keep me interested and closer to home and family. What would you consider a fair "rate" for dispatch, I am with GMan and believe that a percentage is the only fair way, I feel that if I can't do anything for you, you shouldn't have to pay etc, Also, what would it take for you, in general, to go with a "new" broker etc?\ Thanks, Sam |
Hey Gman,
Another question, I have been reading a ton of threads on this forum, and I see guys mentioning that they are O/O's and that they lease to a company, I am assuming that means they move freight for that company, but does that mean they are allowed to move other freight as well, or is that on a contract per contract basis, meaning it would be written into a contract? Thanks, Sam |
Sam, most owner operators only haul freight for the company to whom they are leased. Having said that, most carriers will haul some brokered freight. If you are an owner operator who is leased to a carrier then you must run all of your loads through your carrier. Some may allow you to find a load on your own if they don't have anything, but you will still need to run the load through your carrier. Other carriers may only allow you to haul what they have to offer. They assign a driver manager or dispatcher to find loads for you. If they don't have anything then you will sit until they do. Their policy on hauling outside loads should be addressed in their contract. Some carriers will give the owner operator a higher percentage of the rate if you find the load yourself. Others may only give you the standard percentage or rate. Each carrier makes their own policy. When you lease to a carrier you need to make sure to read your contract very carefully. If there are things in the contract which you don't agree then have them change it or walk away.
Well,
To tell you the truth is that im really not looking for somebody else to get another cut/percentage of what comes out to me.This business is all about cost and it really doesn't excite me having an extra one. For me the way i work is pretty simple.i post my truck on the load board with the different brokers or do a search of what i need to take me to a certain place.Most often i do this from my smartphone.Everything is done over email with brokers and i can even get faxes from them with the confirmation rates.I think anyone that has a little bit willingness can do it with no problem.On a fair rate,it really depends on day to day market activity.This is referring to reefer rates that vary from hour to hour.On the new brokers question,i just dont want to take a chance with somebody that has a problem paying his carriers.This kind of stuff happens constantly and simply cant afford it. |
This question would go out for everyone I guess, what would "look for" in a broker, new to you or not? I am assuming the following, history of business, references, good credit check, integrity, fair. What am I missing there? Thanks, Sam |
I look for a broker who has been in business for a while. I don't do business with any broker who hasn't been in business for at least a year. I check credit and their rates. No matter how good the rate, I don't haul a load unless they have good credit. I have made an exception to the credit on a couple of situations where I am paid with a comcheck before the load comes off my truck. I rarely do a COD. It is a lot less hassle to do business with brokers who have good credit and a good track record. It is a good idea to periodically do a credit check on brokers whom you are doing business no matter how large the firm.
There has been a lot written lately about increasing the broker bond from $10,000 to $100,000. Increasing the bond won't insure that a carrier or owner operator gets paid. Personally, I could care less whether a broker even has a bond or not. They will either pay you or they won't. Those who complain about not getting paid by a broker either don't check the credit or don't do what they are supposed to do with the load. If you do the checks you are not likely to have many problems collecting your money. Another critical factor is the rate. If the broker has cheap rates then I don't do business with them. When a broker has cheap rates is is often due to double or triple brokering. Some may call it "co-brokering." Schneider has arrangements with other brokers and they call it "co-brokering." It is still double brokering. Regardless, I don't take a load unless it has a rate that I can live with. |
Sounds about right, by comcheck, what do you mean there, I haven't heard that term before...
Would you do business with a new broker, who has say been in business for 4 months, but is willing to provide a "deposit" or something similar with that? Or is that a pretty strict guide that you go by? As far as cheap rates, do you continually check with the brokers to see if rates increased, or is there a certain point where you just write them off? Thanks, Sam |
A comcheck is guaranteed funds, much like a bank cashier's check. There are several different types of checks such as comchesk, T-Check, EFS, TCH, etc., They are all basically the same thing issued by different companies. All of them are owned by major banks. We can use either an express code or check. A check MUST be registered in order to be valid.
As I previously stated, I will rarely do business with a broker who has not been in business for at least a year. If there was a load that I wanted to haul and nothing else that I could find from someone whom I have been doing business I might do business with a newer broker. It would need to be a load that paid an above average rate. I don't necessarily have an iron clad policy on that. Each situation is different. The thing is that when you do a COD there is always the chance that the money won't be available on the other end. That means that you will either need to extend credit on someone who is not credit worthy or take the load back to where you picked it up. I usually won't do a deposit on a load. It will either be prepaid before I leave the shipper or paid in full with guaranteed funds before I allow the load to be taken off my trailer. There are quite a few who don't bother checking credit or references on new brokers and are surprised when they don't get paid. I don't want to put myself in that situation. I don't usually check with brokers just to check rates. Each load is a negotiation. You can haul a load to an area today and that rate could change next week or even the next day. It could go up or down. There are some brokers who always seem to have cheap rates. I am always polite, but won't haul their freight unless it is something they must move and they bring the rate up. There are a couple of brokers who come to mind who will take as much as 60% of the line haul. There rates are nearly ALWAYS cheap. Taking that much of the rate is equivalent to stealing as far as I am concerned. The two brokerages I am thinking about are very large. I rarely receive calls from them since they know that I won't haul their cheap freight. I won't say that I will automatically write any broker off, but when they continually offer me cheap freight they are not on the top of my list, especially when I know the cut that they are taking off the top. I may receive calls from them from time to time, but I never call them. |
60% Holy crap, I don't understand how anyone could do that with a straight face,
Like I said before, I was thinking about going into a brokerage as an agent etc, but decided I like the load planning, or dispatching side much much more so I want to focus on that, but even then, I was thinking, at most 15% and probably would have settled on a 12-13% of the rate, anything higher really never crossed my mind, Amazing. Quick newbie question, I see a lot of mention of dry vans etc, just want to make sure I have the definition right, vans isn't what I think it is, meaning an actual van, when someone says dry van they typically mean a trailer for hauling dry goods, right? Thanks, Sam |
Gman,
Appreciate all the help, I couldn't even imagine 20% let alone the 30% etc, I mean, yes, I would like to make a buck in the business just as the next guy, but at that cost I can't imagine they have much business or will have much business for long if they are that greedy, I don't mind charging a fair rate for anything for any work that I do, but man, When you had your dispatch company, how many trucks did you dispatch, and how many do you think one person could do comfortably, assuming the following, A. they spend 40+ hours weekly working, B. they handle the contracts, and billing the broker/shipper so the driver really only has to focus on driving and their own records etc, Thanks, Sam |
Hey GMAN,
Can you PM Me, I am starting to pull all the information together and I wanted to run something by you before going further, Thanks, Sam |
It isn't just reefers that have rates than can sometimes change by the hour. Flats can sometimes be very volatile. It can often be like playing poker. The first guy to blink loses.
What is the point in dealing with a broker when you could find your own load on a board via wireless internet for a flat monthly fee? It seems to me that brokers have become redundant. Drivers now have cell phones and laptops with internet access. The technology is there. The infrastructure which was once needed, when drivers needed to find a payphone somewhere to call-in, is no longer necessary. Drivers should be able to do it all themselves, right? I mean, that's what appeals to me about getting back into the game. I own the truck/trailer. I can find my own loads, and route my own trips. I don't need a company or a brokerage to do it for me and take a cut.
Am I wrong about this? |
I'm guessing that you are partly correct. There almost has to be salesperson/agent/broker involved at some point though, unless the shipper wants to book all of there own trucks. Then I'm guessing that what happens is the load is put out for bid. The first person to get the load might be a trucker or it might be a broker. If the broker gets to it first and you can't get it direct from the first source, then the broker gets his cut if you get the load from him. Then... another broker grabs it up...lol...and on and on... and next thing ya know that $2.50/mile load is on the load boards for $1.37.
The only way to stop the cheap stuff from being put on the boards is for people to stop taking those rates. As long as a broker can grab that good paying load up and repost it with their cut taken out of it, their gonna do it. It's business, they take their proift where they find it just like all the rest of us. Just a guess. I'm no expert and don't have my authority either...so ignore me if you wish..lol. |
It's also time, I have seen Gman state that it takes time to find the well paying load, so it's a matter of choice, is your time more valuable finding the load, or driving the load,
Are you referring to a broker or dispatch service? If you work in this business you will do at least some business with brokers. Even if you have some of your own direct shippers, you will likely do some business with brokers to get back to your shipper. A good broker will usually have more than one account and can possibly offer more than the load that you called about. A dispatch service is NOT a broker. When I dispatch someone I don't rely totally on load boards. I think that I now have over 300 contacts in my file. I can sometimes find a better paying load from my contacts rather than a load board. In fact, I usually start with the contacts. If you run your own authority you can find your own loads. Some people would rather pay a service to find their loads than spend time making calls themselves. It does take time to find the better loads. If all you want to do is keep your truck moving you can easily do that yourself using load boards. Finding a decent rate, or better rate involves good negotiating skills and time. You can't look at a load board while driving down the highway. Many times I have seen a really good paying load be posted and within a few minutes it is gone. If you are not sitting at the computer watching loads being posted you could miss it. Some brokers won't work with you to plan out loads for several days or even a week out. Some will. Those who do that will sometimes offer a cheaper rate. You can always lose the load if someone comes along who will haul the load for less money. As long as people continue to take cheap loads rates will be cheap and more volatile. You can do everything yourself that a dispatch service can do as long as you are willing to spend the time and effort. There are some people who would rather pay someone to do those things for them so that they can be free to drive. It comes down to the value of your time or doing what you want to do. I charged 10% of the rate. As an example, if I booked $3,000 in freight for an owner, then I make $300 and the owner gets $2,700. He cannot pay a full time dispatcher $300. He can find and book his own loads and keep the $300 or he can pay me $300 and keep moving. I may or may not be able to get a better rate than he would have gotten for himself. In the past I usually did better than most of them were able to do for themselves. I figured that even if I only booked loads at what the owner could do, he was saving time and the time saved could mean that he could get another load on the truck this week. That puts more money in his pocket. He cannot look for loads while he drives. I can. You don't have to use a dispatch service to be successful in this business. You can use load boards, computer and cell phone to find and book loads. It is a matter of doing what you want or what you do best. For some, it is driving. For instance, I know people who would rather pay a service to do their quarterly IFTA filings for them. I know others who don't want to spend $35 or more each month for someone to do it for them. They prefer doing it themselves. I find the same thing with a dispatch service. Some would rather pay someone to look for loads and others would rather spend their time and save the money. A good dispatch service can be similar to leasing to another carrier. They find and book loads for you while you drive. The difference is that the dispatch service is less expensive than leasing to a carrier and when it is your authority you will be responsible for doing your own IFTA and compliance. There are some who would be much more successful if they did use a service. There are too many people who are so scared of sitting for a day or two that they will put anything that they can get on the truck rather than wait for a decent paying load. They will take anything just to keep moving. They take a load without checking credit or reading the contract. These are not business people, but they are in business. Unless you make a profit you will not survive in this or any other business. A good dispatch service can not only find loads, but do all the reading of contracts and other paperwork related to the load. If they are experienced they can also advise the owner operator or carrier where he should or should not be running to be most profitable. I have witnessed many changes the last couple of years. There have been times where former good freight areas are no longer very good. It is difficult to keep a handle on this when you are driving. I am not trying to sell anyone on using a dispatch service. That is something everyone must decide for themselves. It works for some people. |
a lot of people just use the wife / family member to do that. Most guys have their dispatcher sitting in the jump seat or back at the house.
I guess I don't see the difference between a dispatch service and a brokerage. Can someone explain this?
Based off of my limited knowledge, simple basics is a dispatcher in theory works for the bests interest of the driver, and a brokerage works for the best interest of the shipper,
That is very very basic, a little bit more complex, a brokerage has to be licensed as he moves other people's freight with other people's trucks, a dispatcher basically finds the freight for trucks, it's a subtle difference in my mind, but a big one I believe. I do believe that if a dispatcher has a direct shipper, they need a broker's license, but I don't know, it is one of the things I was going to ask, So I will let someone more knowledgeable than I take it from here. |
it's just a fancy word for scheduler, travel asst.
Not all dispatchers work in the best interest of the driver. There are some that are in cohoots with brokers.
Music,
That seems like a very good company to use, I was trying to find out how much per report, couldn't find it on the website, can you tell me how much per use? Thanks, Sam |
