-   -   What Type Of Fuel Additive Are You Guys Using? (https://www.classadrivers.com/forum/owner-operators-forums/40247-what-type-fuel-additive-you-guys-using.html)
Aufgeblassen 08-14-2010 04:00 AM
http://www.fppf.com/images/products/fuelpowernew.jpg
I use Fuel Power additive, that I buy by the gallon from a truck supply store in Orlando for a little over $50, which is a lot cheaper than buying 8 oz. bottles at truck stops. I've used FP on a variety of cars and pickup trucks, since I got my very 1st diesel in 1984, an Isuzu pickup.
My original Volvo truck w/ Volvo engine had 538,000 miles on it when I got it 5+ years ago, and I've used Fuel Power since then up to the 1,066,000 miles when I traded it in, and NEVER needed any work on injector pump or fuel injectors during all those miles. :clap:
Shnerdly 08-14-2010 10:23 AM
The only thing I ever added to my fuel tank was more fuel when it got low and a small amount of methyl alcohol when it got colder the -25.
When I serviced my truck, I would fill the fuel filters with ATF (automatic transmission fluid) as a cleaner for the injectors. I had to stop doing that when they started looking for red dye in the fuel to signify the use of untaxed, off road fuel. I was told you can purchase un-dyed ATF but I never pursued it.
repete 08-14-2010 10:31 AM
I don't use any unless it gets down to zero and I'm leaveing the truck for a few days (no place to plug it in) Never had a problem
Aufgeblassen 08-14-2010 10:33 AM
***OR*** You could simply explain to them that you added transmission fluid, and then be on your way. :lol:
flood 08-14-2010 01:58 PM
try it and let us know how much the ticket is.....
GMAN 08-14-2010 02:03 PM
I don't use additives. I think that most of them are a waste of money. I may use a little alcohol in my fuel if I get some water in my fuel. I have also been known to add some transmission fluid. That is all that I use. I have only been checked one time for dye in the tank. I still had the container for the transmission fluid. It wasn't a problem.
Shnerdly 08-14-2010 02:37 PM
I've only been checked twice in over 30 years of driving but I would bet money that the DOT wouldn't care what the explanation was. I agree with flood, If they find red dye in the fuel, I think your going to get a ticket. You may beat it in court if you have all of the correct receipts but it would be a colossal headache.
GMAN 08-15-2010 12:06 AM
A fuel sample would resolve any questions about the content of your fuel tank.
Aufgeblassen 08-15-2010 12:19 AM
The dye is detected by chemical analysis, not by looks!!!
Maniac 08-15-2010 06:33 AM
When its done at the side of the road there is NO analysis, it is the officers discretion, you should know how that will work, and the fine is usually by the gallon based on full fuel capacity, because they will assume that the tanks were completely full of the dyed fuel at one time or another.
Try to fight it in court see whose favor it comes out for. Remember how most states are cash strapped.
As far as additives I don't use any, maybe only if its gonna be real cold.
Heres a link to an oil additive test you might find interesting though
What about Additives?
