peterbilt 386
can any one tell me fuel economy on pet 386
63" Engine Specs Cummins Engine Type ISX Horsepower 485 Transmission 13 Spd Check for Over Drive Yes Engine Brake Yes Suspension Pete Low Air Leaf Ratio 3.55 Tires 22.5 Wheels All Aluminum Wheelbase 235" Front Axle Lbs 12,000 Rear Axle Lbs 40,00 or Cummins Engine Type ISX Horsepower 550 Transmission 13 Spd Check for Over Drive Yes Engine Brake Yes Suspension Pete Low Air Leaf Ratio 3.36 Tires 22.5LP Wheels All Aluminum Wheelbase 248" Number of Rear Axles Tandem Front Axle Lbs 12,000 Rear Axle Lbs 40,000 thanks |
I will say 6mpg but there are alot of variables:
What kind of trailer do you want to pull? Drive in the mountains or plains? You going to drive 63 or 85? How much do you idle? |
Originally Posted by Jumbo
(Post 448952)
What kind of trailer do you want to pull? Drive in the mountains or plains? You going to drive 63 or 85? How much do you idle? thanks |
Cummins or Caterpillar which one is better ?
thanks |
What year is it? Did you mean 550 CAT? Does it have a full fairings, including roof? You also could get an ECM printout, which will tell you what is their MPG is up to date...
Originally Posted by truckmetal13
(Post 448957)
thanks |
Originally Posted by solo379
(Post 448967)
i thinking to buy a new truck . I don't have family and i hope i can earn many for truck and mortgage for my condo thanks |
Originally Posted by Kranky
(Post 448971)
Cat, in my opinion.
(Post 448972)
it's Cummins 2009
I would expect close to 7 mpg as long as you keep your foot out of it. Personally, I prefer CAT. Cummins makes a good engine. Either should serve you well.
| All times are GMT -12. The time now is 03:43 AM. |
