-   -   peterbilt 386 (https://www.classadrivers.com/forum/owner-operators-forums/37798-peterbilt-386-a.html)
truckmetal13 05-04-2009 09:34 AM
peterbilt 386
can any one tell me fuel economy on pet 386
63" Engine Specs Cummins Engine Type ISX Horsepower 485 Transmission 13 Spd Check for Over Drive Yes Engine Brake Yes Suspension Pete Low Air Leaf Ratio 3.55 Tires 22.5 Wheels All Aluminum Wheelbase 235" Front Axle Lbs 12,000 Rear Axle Lbs 40,00
or
Cummins Engine Type ISX Horsepower 550 Transmission 13 Spd Check for Over Drive Yes Engine Brake Yes Suspension Pete Low Air Leaf Ratio 3.36 Tires 22.5LP Wheels All Aluminum Wheelbase 248" Number of Rear Axles Tandem Front Axle Lbs 12,000 Rear Axle Lbs 40,000
thanks
Jumbo 05-04-2009 09:39 AM
I will say 6mpg but there are alot of variables:
What kind of trailer do you want to pull?
Drive in the mountains or plains?
You going to drive 63 or 85?
How much do you idle?
truckmetal13 05-04-2009 09:58 AM
dry van or reefer i will drive not more then 70(65) i will try not idle , some mountains some plains (west and south sometimes east)
thanks
truckmetal13 05-04-2009 10:00 AM
Cummins or Caterpillar which one is better ?
thanks
solo379 05-04-2009 11:44 AM
What year is it? Did you mean 550 CAT? Does it have a full fairings, including roof? You also could get an ECM printout, which will tell you what is their MPG is up to date...
Kranky 05-04-2009 11:58 AM
thanks
Cat, in my opinion.
truckmetal13 05-04-2009 12:01 PM
it's Cummins 2009
i thinking to buy a new truck . I don't have family and i hope i can earn many for truck and mortgage for my condo
thanks
truckmetal13 05-04-2009 12:02 PM
Originally Posted by Kranky (Post 448971)
Cat, in my opinion.
thanks
solo379 05-04-2009 12:43 PM
Originally Posted by truckmetal13 (Post 448972)
it's Cummins 2009
Well, than i can't say...I'd go with 550, gearing seems to be all right for what you are planning to do. Make sure you'll get a full fairings, and don't drive it as a race car. Should be able to achieve between 6 to 7mpg, depending on the loads, and your driving habits... But that's just a guess, I'm not familiar with cummins, especially after the last "modification". Personally I'm a CAT person, but since they are pulling out of trucking business, you might have a better luck with cummins. I hope you know, what you are doing, cause times are really tough...Good luck!
GMAN 05-04-2009 12:54 PM
I would expect close to 7 mpg as long as you keep your foot out of it. Personally, I prefer CAT. Cummins makes a good engine. Either should serve you well.
matcat 05-04-2009 01:51 PM
The Volvo 780 I drive gets 7 to 8 mpg with a load (van), 8 to 9 empty (van), and 12 bobtail.
truckmetal13 05-04-2009 01:53 PM
thanks every one for answering !!!!!!
