Why not just freeze a a gallon jug of water in your fridge, open the door and put a fan behind it. I'm sure that would cool the cab down to 50 when it's 110 out!!!
And what are you going to do when the humidity is 80% outside and your cab is 70. Won't matter, you'll be swimming in a sea of sweat without the dehumidifier that doesn't exist on that unit. |
These are the projected lows for Aug. 20th,usually considered the hottest month of the year. http://i125.photobucket.com/albums/p...us__tonlow.gif http://i125.photobucket.com/albums/p..._predicted.gif |
Well, you can try and justify it all you want but I'll be in comfort and you will be sweating your azz off and Rev, we'll, he'll be on fire.
I don't like the idea of it because even if it does stay frozen long enough, it is still adding humidity to the truck, which is never a good thing.
From their web page:
The BlueCool Truck air handler is installed in the sleeper and features a control panel that operates both the fan, temperature, is able to dehumidify the bunk and can also be used as a circulating fan. BTW - who knew that an Air Conditioner could start a heated argument. |
http://i125.photobucket.com/albums/p...aelsop/sig.jpg |
Originally Posted by mike3fan
for 10k,you should be frozen in the summer and toasted in the winter,some have better things to spend money on.
Mike what did you pay for your Espar installed?
| All times are GMT -12. The time now is 05:19 PM. |
