-   -   Bio Diesel or B100 and how does it work for you? (https://www.classadrivers.com/forum/owner-operators-forums/32725-bio-diesel-b100-how-does-work-you.html)
Shagnasty 03-02-2008 11:00 AM
I make bio diesel or B100.
There is an active club that I am in and we teach others all about making the B100 and the cost savings in doing so.
Does anyone run B100 in there truck and how has the performance been since they started running it?
Orangetxguy 03-03-2008 02:07 AM
Bio-fuel in a trucks is bad. Worst fuel mileage I get is with B-10..B-20 is bad too.
Shagnasty 03-03-2008 02:30 AM
Thank you for your input on your bio diesel reply....
B100 or straight bio diesel is a high solvent liquid, but needs a warmer temperature to operate properly. An additive is needed in colder climates. Also B100 was used for a TransAtlantic flight with a jet and the owner was Branson, owner of Virgin Airways.
Orangetxguy 03-03-2008 03:47 AM
LOL.... So..your here to promote Bio-fuel?
Tell me...what process do you use to manufacture Bio-fuel? (yes..I know..it is proprietary)
What is your source of raw material? (IE; Soybean, corn, rice, fruit, etc.)
What energy components do you use to process the fuel? (IE; Electricity, natural Gas, Propane, Hog fuel..etc.)
If you bothered to read the articale on Virgin's "Bio-fuel" flight..they flew the plane from Heathrow airport to Amsterdam....about 250 miles...with only a "portion" of the flight powered by bio-fuel. They do not say how much of the flight was powered by bio-fuel specificly, nor the quantity of fuel used during flight..nor do they specify what percentages the "carbon fuel to bio-fuel" mix was. They do allude to having tested a 60-40 mix. :roll: :roll: :roll:
I know of a company based over in Conroe TX that makes Bio-fuel. They tried to run their company pickups on "pure bio-fuel". In 100 plus degree heat, the fuel was to thick for the fuel pump to move. They had to cut it to a 75% diesel-25% biofuel mix, before the fuel pump could move it..their fuel mileage on that mix was 3.5 miles to the gallon...in a Chevy Pickup with a Duramax engine. They now use a mix of 80-20 for their pickups and their CMV's. They haul their components used to manufacture bio-fuel from a plant in this area. One component is sodium-methylate the other is naptha..both of which are "petroleum" based ingredients.
I'm all for clean air. I however, do not accept the "con" that goes into "green" fuel alternatives. Oxygenated gasoline is good for the air....bad for ground water. Bio-diesel is good for the pocketbook of those whom produce it..bad for the pocketbook of those whom purchase it.
Why is it people want to impress with their "green" fuel, while ignoring the fact that the production of bio-fuel consumes more "carbon" energy than it replaces, while the actual use of the bio-fuel, reduces the miles per gallon a vehicle gets from that source, there-by causing increased consumption of the base fuel...diesel? Exhaust that smells like french fries was "novel" when it started...but I do not buy it.
By the way...Pilot Truckstops, the largest marketer of Bio-diesel(B-20) on the Gulfcoast...stopped selling it during the winter months, due to the "gel" factor.
Shagnasty 03-03-2008 04:16 AM
Our club uses soybean and or canola....
We have selected places for pickup, hospitals, pizza parlors, clubs etc etc.
What we use is electricity to heat the mixture up in a 40 gallon hot water heater, we add lye and methanol alcahol (sic), alky race fuel for funny cars, we could use an acid, but choose ALKY instead.
We get back 99% of the ALKY through a distillation process.
Also we get glycerin for washing our cars and trucks, dish washing, clothes washing too. We also get soap as a result so nothing goes to waste. The 1% of ALKY is dissapated, but we are looking to convert that into a vapor process to use in something we are working on.
Our trucks and cars run on B100 and have had no problems with it at all. Except for eating of rubber fuel line/piping, you need to replace your piping with a syntheltic or it will eat it to &^$$&.
We are just a small club, but we do have a new Duramax 4x4 that does 10's in the quarter mile and also gets 31 MPG on the highway. It has a lap top tuners kit and runs a special program anyone can down load.
Also we have grease cars, which are cool too.
My turbo Mercedes Benz 300 SD does get a little less mileage, but the inside of the engine is spit polish clean of carbon I bet.
I am working on a heating system to bring the temperature up before injecting it and seeing if that helps the MPG out.
Did you know you can have a hydrogen injecting system for your big rig I read about that somewhere.
I can get you the URL for you to peruse at your leisure. It is a system that makes hydrogen from a very simple and highly economical source and power.
Also I do know we use propane and Nitrous in our fastest B100 toys, that's interesting. To much nitrous and the motor just shuts down, no problems.
Also I am working on a Sterling motor and or water fired V8 using 210 volts to fire it up burning waters hydrogen gas that is in H2O.
The water powered V8 uses regulat tap water or from a lake. One injects it into the engine via a carburetor. There is a 12 volt battery that converts from an inverter 12 volts DC to 210 AC. You use 8 solenoids to fire the motor. This is all hyporthetical but is may work, so I am looking into it.
I am not a mad scientist at all.... but an inventor and like playing.
Oh... I ran 40% B100 in my 2007 Chevy Tahoe 4x4 to see how it ran. Actually it ran fine, but the cylinders washed down and into the oil which added to the oil and I had to change it. How ever it did run and just made a little knocking noise. Instead I will run 10% B100 and see what it does at the dragstrip and fuel MPG too this Summer.
On the Virgin jet using biodiesel.... Apparently I just read the article for it's worth of excitement off of jet fuel. But... the USAF did run a jet on it and it ran fine. Still a lot of experimenting needs to be done.
Orangetxguy 03-03-2008 04:37 AM
:lol: :lol: :lol: :lol:
All the various problems you mention, with your "home-brew" fuel. When you add it all up, it is not worth the expense. :roll:
Yes..I have heard of the various scemes to improve fuel mileage in CMV's. Unfortunately that is all they are..scemes..time consumng scemes at that. :roll: :roll:
Shagnasty 03-03-2008 04:38 AM
http://waterpoweredcar.com/
Shagnasty 03-03-2008 04:46 AM
Well I guess we all have fun.....
We meet with all our toys... www.IamCarCrazy.com
I am looking to put a Duramax diesel in my McLaren turbo M6B-GT concept car and run B100. Also I want to do experiments with the diesel turbo MBZ. See what kind of mileage I can get out of a 1981 VW Rabbit turbo diesel running B100 as well.
There are a lot of others out there running there cars with experimental fuel systems and fuels. One being a car running on a mixture of green slime or algae. I am thinking of a way to test on some other oils out there, maybe even a grassoline kind of thing.
The apple had to have fallen from the tree and Issac knew what to do....
In the mean time all of us guys are just enjoying life and meeting some very interesting people. The knowledge base we all share thoughts in, just makes for that wonderful think tank of lfe.
Shagnasty 03-03-2008 04:59 AM
canola seed (RME) starts to gel at approximately -10 °C
We use.... canola seed (RME) starts to gel at approximately -10 °C for the winter time...
Trukrswyfe 03-03-2008 05:01 AM
If one really looks to call one's self green or even an conservator of the environment I'd suggest they get away from the media hype and truly research the topic of "green house" and air polution.
Water vapour accounts for more the half (depending on the study) of the cause for the "green house effect" that IS NOT yet proven.... Just because Al Gore and other talking heads say it is so doesn't mean that is it.
Right now has just become popularized to call yourself green. It is a fade,
I myself love the environment and fight against unneccesarily abusing it. But Carbon and other populates are trace gases and water vapour is the largest source of polutants. Check it out for yourself and don't rely on other with an agenda to inform you.
http://www.geocraft.com/WVFossils/greenhouse_data.html
There are many other sources of this data... Dont take my word for it either Who the heck am I? I am certainly not a paid actor(hypocrite).... with milllions to spend pushing my views on others.
Shagnasty 03-03-2008 06:44 AM
Can we have an ahmen to that
Can we have an ahmen to that....... I agree!
Also when a volcanoe erupts that is spewing crap into the atmosphere, just another of mother natures way of talking it all up.
I also believe that oil is a renewable source and that is constantly being made deep in the earth. We will never run out of it like salt water is to the ocean.....
A friend of mine that is a physisist (sic) said so and I believe him......
sidman82 03-03-2008 07:04 AM
I am going to buy an air car. The one that runs on air. :D They are working on a generator to run a compressor to refuel the air tanks. You would then be able to run forever on air. Only downfall is no heat in the winter. Anybody see the tv show on them. They look like golf carts.
That's my green.
http://www.gizmag.com/go/7000/picture/32542/
Doghouse 03-03-2008 11:19 AM
What about the companies that use animal products in their Bio-Diesel? what is you opinion on this? could my truck get Madcow from this?
sidman82 03-03-2008 01:08 PM
Bad Bio and your car will drive erratically and put itself into the rue-barb with madcow :P
Shagnasty 03-03-2008 01:30 PM
Yes I have....
That's my green.
Copperhead 03-04-2008 02:16 PM
Re: Can we have an ahmen to that
Well said! I agree!
Shagnasty 03-21-2008 05:54 AM
Re: Can we have an ahmen to that and more
I am buying a centrifuge to make my bio diesel really really clean. A ten micron is fine, but I want to make it even cleaner if possible.
Use a tied blue jeans pant leg for a strainer if you have to.... don't walk around naked in lew of clean fuel... :)
Well said! I agree!
Blind Driver 03-22-2008 07:52 AM
I'll be making bio-diesel this spring. Got any good plans for a easy home-brew system? I can't seem to find anyone near me for advice. Slowly gathering information off the internet...very time consuming, but interesting.
I'd rather not scour the land for used cooking oil, but am looking to buy veggie oil in bulk. Any good companies out there selling bulk?
Orangetxguy 03-23-2008 01:39 PM
You "Hobby" fuel refiners are cute. :lol: :lol:
Try making enough fuel to operate a truck profitably...then tell us how you do!
Don't dump your waste products from making bio-diesel into your city sewer system either..it passes through the system without being cleaned..enters the eqo-system you are trying to protect, then kills tens of thousands of fish.
http://newsdemocratjournal.stltoday....-fish0.ii1.txt
DE SOTO: Officials warn of biodiesel hazards
By-products of fuel can kill fish
By Sarah AuBuchon
Tuesday, March 11, 2008 2:18 PM CDT
A huge fish kill last summer in a De Soto stream has spurred city officials to educate people on a potential hazard of making their own biodiesel fuel.
Biodiesel, a renewable energy fuel made with lye, methanol and vegetable oil, costs around 70 cents a gallon and can be made at home. With diesel prices inching up to $4 per gallon, De Soto Public Works Director Kevin Warden thinks more people could soon be brewing the stuff in their garage.
"Biodiesel is very easy to make," Warden said. "You can use soybean oil or vegetable oil, and it's biodegradable and nontoxic. I saw a video on the Internet where someone was actually drinking the stuff."The problem doesn't lie in making biodiesel, Warden said, but from its by-product, crude glycerin, also known as crude glycerol.
Lance Dorsey, Missouri Discharge Management Resource Quality Assurance state coordinator, said crude glycerin by itself is relatively harmless, but when it gets into a stream, it kills fish.
"Milk and molasses will do the same thing," he said. "It depletes the oxygen the fish breathe and that's what kills the fish, invertebrates and even the microbes in the wastewater treatment plant that help break down the wastewater."
More than 4,000 fish were killed in Joachim Creek in August after the by-product somehow got into the city's sewer system. Warden said there are hundreds of Web sites and videos on the Internet that show people how to make biodiesel, but none of them explain the hazards of dumping crude glycerin.
"Spike TV had a video of their show 'Trucks' on 'YouTube' and the gentleman was showing people how to make (biodiesel)," he said. "He told people to throw it away. You just don't do that."
The Missouri Department of Natural Resources (DNR) has several recommendations for disposing of crude glycerin properly.
One way is to mix it with sawdust and then haul it to the landfill.
"Don't just put it in the trash can," Warden said. "It could cause spontaneous combustion at the landfill."
Crude glycerin may also be used in livestock feed, but Warden recommends calling the DNR for amounts. It can also be burned in a cement kiln or even sold on the Internet.
"There are hundreds of uses for it," Warden said. "It's used in toothpaste, cosmetics and soap. You can sell it, but the market is so saturated right now that it's only going for one or two cents a gallon."
While making biodiesel is legal, people caught dumping crude glycerin could face fines, Warden said. The city recently had to pay $2,891 to the DNR for the August fish kill.
"Since biodiesel is legal to make in an individual's home, as long as it's not sold for profit, it is critical that anyone who is making it or planning to make it must contact City Hall," Warden said.
Warden said the city is taking precautions to help prevent another fish kill.
"We bought a $5,000 ph monitor that will tell us if the ph changes in the water," he said. "Hopefully this will allow us to respond faster."
The city also bought video cameras to monitor the sewage treatment plant.
"The last time it happened, the water turned white when it hit," he said.
Dorsey said both the DNR and the Environmental Protection Agency are working on fact sheets related to biodiesel and crude glycerin.
For more information on crude glycerin and its disposal, call Dorsey at 573-522-4506, or Warden at 636-586-2499.
For more information on biodiesel, visit the National Biodiesel Board Web site at www.biodiesel.org.
I'm just sayin.....and I wouldn't drink nuthin ya made in yer garage either. 8)
