HOS question
Just want to double check something. Quite sure I know the answer, but I'll ask it anyway because I beleive it's different than the Canadian rule.
Under US rules, if I started my day at 06:00, drove for 8 hours, went off duty for 4 hours, how many more hours can I drive that day? |
1.75hrs, with a .25 hr post-trip would wrap up your 14hr day before a 10hr break.
So those 4 hours off duty actually count against my on duty hours ?
I was thinking I could drive 11-8 = 3 more hours. |
I'm pretty sure that once you turn the key, your 14 hour clock starts.
I was thinking I could drive 11-8 = 3 more hours. sleeper time of at least 2 hours does stop the clock, but you can still only drive 11 so if you started at 6 am, drove until 2 pm, took 4 hours sleeper time, came back on at 6 pm, you have 3 more hours to drive, then you must take another 8 even though you already took 4 because now you can take 2 sleeper periods but one must be at least 2 hours and one must be at least8 this is because a panel of idiots who have never even seen a truck up close determined that it's much safer to make you drive 11 hours a day and then take 10 off than it would be of you could stop and nap when you get tired and not be penalized for it. and I know I didnt figure inspection time or any of that, just trying to keep it simple |
I was thinking I could drive 11-8 = 3 more hours. so if you started at 6 am, drove until 2 pm, took 4 hours sleeper time, came back on at 6 pm, you have 3 more hours to drive |
Originally Posted by mike3fan
Just for clairifcation the clock does stop with a 8 hour break,you can use this to split your sleeper berth or off duty requirement,but for the clock to stop it must be atleast 8hrs in duration.
yes it will as long as you take another 8, it has to be 8 even though you already took 4 G-3. How does a driver who is utilizing the sleeper berth provision calculate his or her compliance with the 14-hour rule? A sleeper-berth period of at least 8 consecutive hours is excluded from calculation of the 14-hour limitation. All other sleeper berth periods are included in the 14-hour calculation (unless part of a sleeper-berth/off-duty combination of 10 or more consecutive hours). |
I think they did away with that. When I started a few years ago, my Dad told me a sleeper birth could stop the clock. That has changed, but I'm not 100%.
What I would do in your (rank) situation is different than others might to get more drive time :wink: |
1 doesn't stop the clock at all, only resets it.
2 stops the clock if it is at least 8 hours. Unlike canada, which is any 2 hours of 2. But still, 16 hours is a lot anyways. |
thanks 2 all |
thanks 2 all |
Yeah thanks Cat I got it. Back at ya.
Originally Posted by Cat6869
USA RULES
| All times are GMT -12. The time now is 09:12 PM. |
