Anyone use a gasoline generator to heat sleeper/block?
Another option I have been considering is to mount my 3500 watt generator under my trailer. I have a good place to mount it where the old spare tire brackets were (the rack is no longer on the truck). I could weld up a rack to mount it on and carry a couple five gal buckets of fuel alongside it. Then run a cord up to the truck to power a small electric space heater and another to the block heater.
Has anyone tried doing something like this? :roll: :? |
DOT might (will ) have a problem with the gasoline can thing for the generator...
I wondered about that. I don't know the regs on it offhand. Perhaps if it were "concealed" properly??? 8)
Quote: Perhaps if it were "concealed" properly???
This is the kind of stuff that keeps the Fire Depts and Emergency Rooms in business.... if you live through co poisoning, the wreck or a fire. :? |
Why do you say that Kurbski? Maybe some folks don't have enough sense to properly transport and operate a generator. I have used one for years while camping and see little difference in using it for my truck. But then, I have also survived 28 years as a pilot, 20 years in police work, and 6 years paragliding. Regardless, it could be done safely; would hinge more on what DOT says than anything.
That's not the impression I got from you "concealing" it in your post which mentions nothing about safety... So Thats why I posted what I did because exhaust from generators is poisonious.and crashes/fires etc..
That's all. It seemed like a "sneaky post" like your going to hide something from DOT man. No biggie since you posted your resume. |
I will share a little consultation I did online with an experienced old trucker who runs a Honda 3000
Yep, we did it last winter and also used one this summer while logging. DOT never said a word to us about it and we were inspected more than once in NC. :wink:
We are going to use it again this year too. tootie |
I've been thinking about setting up something based on a honda generator, more than likely the EU3000IS model. MSRP on this unit is right around 2 grand. It is very quiet at 58 decibles, and would be even quieter mounted as described below.
What I'm considering is mounting the generator inside a box mounted on the frame rail and tying the exhaust into the trucks exhaust system. Vent the box with two fans, one sucking and one blowing. Mount a 10 gallon foam filled fuel cell between the frame rails under the catwalk. It would be easy to securely mount everything and have the wiring and fuel lines protected from road hazards. Mount the starting switch, oil pressure guage, and breakers remotely in the sleeper where they are easy to get to. It would then be an easy task to wire in a gang box with a few outlets inside the sleeper. During the winter, the block heater could be run on a switched circuit. Most block heaters pull from 750 to 1000 watts, so the generator could easily power that as well as another heater for the cab. Running a fridge would be easiest with an inverter I think, just so it can stay on most of the time instead of only being on when the generator is running. What I don't know, is if inverters are rated to be run continuously for something like this? Setting up a battery minder to run off the generator would be a good idea too I guess, to keep them up while the inverter is running. Sure, something like this would take some work to get all set up, but in the end it would still be far cheaper than an APU. Oh, and yes, I will be checking with the DOT about the legality of running a setup like this. I have read way too many differing points of view regarding the legality of having a gas generator on a CMV, none of them official or linked to a law that would allow or prohibit this. |
My refrigerator will run for 3-4 days on my inverter with my truck shut off. If I go 3 days or so, it will run the batteries down. But I leave my refrigerator on at nights when I am parked, plugged into the inverter, and the fridge alone won't drain the batteries.
I don't think DOT would give a whoot on a well designed setup. Probably most would not even know the code applicable, if in fact there is one. It's all about safety, and a good setup done safely would not be any more hazardous than any other fuel based setup. I run the same trailer all the time; that's why I'm thinking of mounting my generator on the trailer. For winter use, it would do the trick, I think... |
(a) Application of the rules in this section. The rules in this section apply to systems for containing and supplying fuel for the operation of motor vehicles or for the operation of auxiliary equipment installed on, or used in connection with, motor vehicles. (b) Location. Each fuel system must be located on the motor vehicle so that — (b)(1) No part of the system extends beyond the widest part of the vehicle; (b)(2) No part of a fuel tank is forward of the front axle of a power unit; (b)(3) Fuel spilled vertically from a fuel tank while it is being filled will not contact any part of the exhaust or electrical systems of the vehicle, except the fuel level indicator assembly; (b)(4) Fill pipe openings are located outside the vehicle's passenger compartment and its cargo compartment; (b)(5) A fuel line does not extend between a towed vehicle and the vehicle that is towing it while the combination of vehicles is in motion; and (b)(6) No part of the fuel system of a bus manufactured on or after January 1, 1973, is located within or above the passenger compartment. (c) Fuel tank installation. Each fuel tank must be securely attached to the motor vehicle in a workmanlike manner. Can't strap a gas can to the catwalk... (d) Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector. (e) Selection control valve location. If a fuel system includes a selection control valve which is operable by the driver to regulate the flow of fuel from two or more fuel tanks, the valve must be installed so that either — (e)(1) The driver may operate it while watching the roadway and without leaving his/her driving position; or (e)(2) The driver must stop the vehicle and leave his/her seat in order to operate the valve. (f) Fuel lines. A fuel line which is not completely enclosed in a protective housing must not extend more than 2 inches below the fuel tank or its sump. Diesel fuel crossover, return, and withdrawal lines which extend below the bottom of the tank or sump must be protected against damage from impact. Every fuel line must be — (f)(1) Long enough and flexible enough to accommodate normal movements of the parts to which it is attached without incurring damage; and (f)(2) Secured against chafing, kinking, or other causes of mechanical damage. (g) Excess flow valve. When pressure devices are used to force fuel from a fuel tank, a device which prevents the flow of fuel from the fuel tank if the fuel feed line is broken must be installed in the fuel system. [36 FR 15445, Aug. 14, 1971, as amended at 37 FR 4341, Mar. 2, 1972; 37 FR 28752, Dec. 29, 1972]. |
With the setup I have in mind, I don't see a problem meeting everything that is required or staying away from the prohibited.
Thanks. |
That generator is gravity fed although you really can't tell without taking it apart. I doubt if anyone would give you any grief about it.
I'm assuming gravity feed is a no no because the fuel line could break and leak gas over everything where a pump feed is sucked out of the top of the unit and can't leak. |
Just my 2 cents worth
I think the regulations that are being posted here apply to the vehicle.... A Generator is and add on unit and I have never seen anything that says yes or no to a generator being mounted to a CMV........ Examples......... RGN's that are self contained have a gas engine on them.... older car haulers were self conained... Gas Motors...... Landall trailers can be self contained...gas motors...... look at tankers with that big box mounted under it .........Gas Motor.... And if my memory serves me correctly flammable liquids is 1500 Pounds or a number of gallons to be Haz Mat ( I do not pull haz mat ) The generator I have was built in 1968 and came off a B-52 and has a fuel pump and the tank is mounted to the gen |
§393.65 All fuel systems. (a) Application of the rules in this section. The rules in this section apply to systems for containing and supplying fuel for the operation of motor vehicles or for the operation of auxiliary equipment installed on, or used in connection with, motor vehicles. |
I Stand corrected
...Gravity or syphon feed prohibited. A fuel system must not supply fuel by gravity or syphon feed directly to the carburetor or injector. ... Gen MUST HAVE A FUEL PUMP ..Fuel tank installation. Each fuel tank must be securely attached to the motor vehicle in a workmanlike manner. ... ...gas can is not a fuel tank ( yes some red neck could use it that way but I don't think that is the way it is being used here ...it is a gas can used for storing extra gas for the generator Big Diesel IM not picking a fight ...just getting facts straight.... |
When I bought my truck it had a gravity fed 5,000watt genny under the sleeper. The guy who rigged it drilled a hole in the gas cap, and then sealed it shut with blue RTV silicone. He put a 5 gallon tank on the catwalk and off he went.
Only problem was that the silicone let go and then he would use the shutoff valve to stop the fuel from leaking out of the full original tank while he drove, but when he used the genny, it would seep diesel fuel all over the place. Now,...if he had removed the original tank from the genny and then piped the catwalk tank into the fuel pump supply line,...it might have worked,.... Oh,....he also let the exhaust blow upwards into the bottom of the sleeper (let me tell you what a mess that was to clean up). So,....if you have room, just put the genny on the frame rail below the sleeper, remove the tank, then put an aux tank on the catwalk,pipe it into the gravity fuel line at the carb...and walla,....instant power. But be carefull, the higher you go above the genny with the fuel tank,,the more PSI on the carb needle and seat,....it could flood while running, or just overflow all the time. A regulator might be needed, and it will take time to get the fuel flow right, but it will work. Also,..some of those portable genny's are loud as hell, and I don't mean the exhaust,...I mean just the noise from the unit itself. The more $$$ the quieter you will get. Rest assured,..anything you get from Home Depot will not be quiet enough to put on your truck. Or you can be a puss like Steve O, and get a fu#4ing whimpy a$$ rigmaster :roll: |
Or you can be a puss like Steve O, and get a fu#4ing whimpy a$$ rigmaster :roll:[/quote]
That dang Steve, he has all the toys... I appreciate the comments and ideas gents. I believe this idea has potential, and I would go so far as to get a fixed gas tank and mount that between the main rails on my trailer to make it happen. Dunno how to figure out the electric fuel pump you'd need, but I bet it can be done! :? |
It easy flyer,...just find out how much fuel psi the genny you want runs on, and then get an electric unit that is close,....put on a regulator, and run it till you figure out where to set the regulator at.
I had an old 280z that was fuel injected. I took off the injection system and put on 3 side draft carbs,...it took some time to figure out the correct fuel psi,..but after that is was trouble free, for 50,000miles,....till I sold it anyway. |
I appreciate the comments and ideas gents. I believe this idea has potential, and I would go so far as to get a fixed gas tank and mount that between the main rails on my trailer to make it happen. Dunno how to figure out the electric fuel pump you'd need, but I bet it can be done! :?[/quote] Hello Mountain Flyer I used a 5000watt coleman gas gen that was mounted on my cat walk for the last 3 years before I came over here and never had any problems with it or with the DOT over it. But like they said it was noisy !!! When I come back home next year it will go in a bax I had made for it and I will pipe the exhaust through the truck exhaust as well. If I was going to do it all again I would buy a diesel gen out of a place in LA that sells them for about 1000$ for a 6500 watt gen then put it in a box on the frame n tie in a line to the truck tank on a small fuel pump with a remote start. I also had a big inverter and used it a lot but here again I will change things and set it up on it's own deep cycle batt that recharge when the truck is running. Household electric in the sleeper opens up a lot of option for you and very quickly pays for it's self. Refrigerator --George Foreman Grill--Coffee Pot--Slow cooker--Electric Skillet ect ect ect just like being at home. Good Luck to you and stay safe !!!! |
they make a small fuel pump for racing go karts works off vacume from the engine would be perfect for a generator.but a better idea would to buy one of the small quiet generators that runs on diesel.it would last much longer and can be plummed into the trucks tank.i got mine off e bay less then 800 shipped to me 6500 wattsvery quiet with electric start and remote start unit.
Don't forget most block heaters draw closer to 1800 watts and the small space heaters for inside the bunk can draw as much as 1500 watts. I ran a 2600 watt Yamaha campground model for a few years and never had a problem with the DOT. Mine was in a ventilated box so most people never knew I even had one. If you're going to run it in the summer you'll have to vent it really well. If I was doing it know I would probably get one of those cheap chinese diesel ones too.
in front of you and ashca, do you have any brand name or company links for the units you have? those sound good...
i dont know the name just search on e bay for diesel generator there are a bunch on there.
Here's a link to some low cost diesel gens with elec start:
http://www.duropower.com/index.asp?F...FQsQUAodPT9gmA |
Just stay away from a company called Atrans,...they make an APU designed by truckers,...for truckers :roll: ,.......and I spent 2 weeks just getting the thing to run right. It arrived with loose connections, loose bolts,...really poor instructions (at on point I just yanked off all the wires and started from square one). The unit looked like a 10th grade shop project.
I also can't vouch for reliability,..not till I actually use it for more than 4 hrs testing it. |
Didn't Volkswagen beatles have gasoline heaters?
come to think of it, there must be some diesel powered heaters out there. I'm thinking military surplus.
Steve. What exactly are you talking about? I know of many old VWs that never had that.
the volvo we drive has a bunk heater that uses the trucks fuel dont know exactly how it works but ill tell you it will run u out of the truck with the heat it makes
Probably an east coast VW. Yep, never had those on the left coast.
Aahhhh, the old gas heater for a bug,..here's a link to one on E-bay. These heater would cook you out of the car,...and in good condition they were very safe :D ,....but after some years of neglect,......not so much :cry:
http://cgi.ebay.com/ebaymotors/VW-BU...em270186735746 |
The - 70's model Volkswagon 411 also had a gas heater in it. It was a big step above my 1966 vw air cooled camper that would only run so fast in freezing weather. The plastic cup actually froze on top of the thermos one morning on the way to Portland at 20 below after i poured the first one. Always plugged in block heater and a light bulb near battery the night before.
