The gas power leaf blower is the way to go
and a bag charcoal will help get the stink out plus if you have a load of strawberries it will buy you a day or so to stop mold. |
Yes Geomon you summed it up right. I like the charcoal tip Volvo thanks.
$900 isn't all that bad. When i worked for TMC, i parked the truck at a Home Depot Expo Center nearby, and there were a couple of trucks there every weeekend, I parked there for more han 3 months, no problems.
so they tow it, about 3 blocks away, $1545 later i got the truck back. Fortunately i didn't have to pay. but it still hurts to know that ppl want their sh!t asap, as far as goods, but don't want to see a nice looking truck anywhere... but than again this is NY... |
What happened at TMC BND? Doesn't seem like you were there that long. I remember reading your post on the TMC thread when you started. What are you doing now?
Hello, cleaning is done by dissolving impurities in the water, melting paraffin-like substances and oils, as well as the mechanical effect of the jet. If you use nozzles that create an additional mechanical effect, the cleaning power of the steam generator increases significantly. There are different types, the most effective are the steam cleaner for cleaning . With such a steam generator, you can remove traces of grease, fats, oils, some resins, wax and wax.
I use a regular machine that releases water under pressure, the analog of a Kercher.
| All times are GMT -12. The time now is 03:58 AM. |
