-   -   Radio antennas (https://www.classadrivers.com/forum/owner-operators-forums/24677-radio-antennas.html)
ToxicWaste 02-08-2007 07:21 AM
Radio antennas
What type of antenna are you using for your sirius/xm radio? Are the ones specifically designed for trucks better than the one that comes with it?
Red Clay Rambler 02-08-2007 08:28 AM
All I've ever used was the magnetic antenna about the size of an egg. Mine just sits up in one of the small storage compartments above the windshield, inside the cab. Almost never lose the signal except under the fuel island awning.
flood 02-08-2007 09:47 AM
we have xm & sirius both all we use is the little mouse looking one suction cupped to the inside of the skylight on our volvo
marylandkw 02-08-2007 10:00 AM
http://www.myradiostore.com/antennas...enna-xmt4.html
This is the one I use for XM and it has been leaps and bounds better than the stock one. Aside from tunnels, I never loose signal.
A couple of pointers on it..
1. Mount it as close as possible to your AM/FM antenna if you are rf broadcasting your satellite signal to your AM/FM radio.
2. Mount the antenna on the drivers side. It is less likely to be caught up in trees on narrow roads and be broken. That was a $60 lesson for me, and you get it for free. :lol:
bibnflannel 02-08-2007 01:20 PM
I use the sirius antenna that came with it and its magnetically stuck out on the pass. side on the visor, allthough I did have to buy a device to hardwire the signal from the sirius reciever to the am/fm radio in the cab to prevent local radio stations from bleeding thru when youve selected a frequency to run the sat. radio from.
Parts guy 02-09-2007 12:23 PM
Which radio did you buy?
When satellite radio first came out the antennas were very unreliable. I sent dozens back for warranty. The small mouse antennas they have now work well. There is no need to mount them outside your truck. Most of my customers mount them in the headliner or throw them on the dash and they work fine.
Jackrabbit379 02-09-2007 03:10 PM
Re: Radio antennas
I have the Sirius Visor radio. I use the antenna that came with it. I just place the antenna on the dash, usually, on the left corner. Works fine.
nrvsreck 02-10-2007 03:11 AM
Where did you find an FM modulator? I've been hunting the 'net and it seems all the FM modulators are discontinued. Where do you get one?
marylandkw 02-10-2007 05:09 AM
http://www.myradiostore.com/fmmodula...modulator.html
That is one, you don't have to use the power adapter part but it does have an earphone type plug to do the fm modulator function.
I know I have recommended this site twice in this thread and numerous times in other threads but I have no connection with them whatsoever. I am just a satisfied customer after ordering things from them on many occasions.
bibnflannel 02-10-2007 10:36 AM
I got mine at Best Buy, it was about 20 bucks
ToxicWaste 02-10-2007 12:54 PM
I was going to buy one that mounts to the antenna b/c I thought it had to be mounted outside the cab. I have sirius in my house but haven't put it in my car or truck yet. How good does it transmit to the fm radio?
marylandkw 02-11-2007 03:12 AM
I have XM and it transmits flawlessly to the FM radio as long as the satellite antenna is close to the FM one. I am fairly certain Sirius is even better. My friend has Sirius and I can hear it in my truck if I am within a quarter mile of him.
nrvsreck 02-11-2007 10:37 AM
http://www.myradiostore.com/fmmodulators/delphi-roady-wireless-fm-modulator.html
Hmm... that one is out of stock too. What's the deal with everything being out of stock or discontinued??? :?
marylandkw 02-11-2007 01:26 PM
http://www.myradiostore.com/fmmodula...c-adapter.html
Sorry about that, I could have sworn it was in stock. This one is in stock as of right now.
Parts guy 02-12-2007 02:05 AM
When Sirius first came out with the FM transmitter on their radios my Pana-Pacific rep came by the dealership to demo them. He did that by leaving the Sirius radio on in his car in the parking lot, walked into the dealership and tuned our AM/FM display radio to 88.1(the station he had his Sirius set to broadcast on). We could hear his Sirius loud and clear on our display radio and his car was parked in the parking lot about 20 yards away.
This is a solid radio that you can get from most any KW or Pete dealer and some truck stops...
http://www.panaoem.com/productsDetai...&categoryID=18
You can get one in the $70-$80 range.
