What are company drivers' responsiblilities for IFTA?
I am scheduled to go out of my state for a pick up. The box truck I am supposed to drive does not have apportioned plates and only has New York H.U.T.
Does the responsibility to produce proof of taxes (IFTA) fall on the driver or is the carrier solely responsible for compliance of these laws? In otherwords, if I can not produce proof of tax documentation for a particular state, is that equivalent of say driving without proof of registration? I use a log book and it is easy enough to keep track of how many miles I drive in a state but I can't make my boss pay the taxes. |
Re: What are company drivers' responsiblilities for IFTA?
The fine for not having your IFTA registration is quite hefty - It is like driving a car with no plates. |
The company should have the needed permits in the truck. It is your responsibility to check to see that you have everything you need to be legal. If you are in doubt, you should get with your company before taking the truck out of state.
Every so often look in the permit folder they gave you and keep an eye open for expiration dates.
I told my boss that I didn't think the truck could legally go out of state and he told me that it wasn't my responsibility when I asked whose it was. I would not knowingly drive a truck with no registration or insurance. Does this fall under the same category where I ought to refuse to cross the state line?
Drivers responsibility-Your Butt
Actually you may or may not be legal. What is the Registered weight of the vehicle? You say a box truck. If the truck's gross is under 26,000 lbs, then you are not required to follow IFTA or IRP laws.
Even so, over 10,001 you have to have a DOT number to cross the lines, and if your gross is over 26k, then yes you will need temp fuel and trip permits. Like the rev said, 9 chances outa 10 if your butts covered, ie logs, etc The technical end is going back on them. However an OOS out of service, will surely ruin your day, and if they find some hefty violations off the bat, they are sure to dig in a little deeper. If the employer does not provide you with temp permits, report him to Dept of Labor and Industry, or whoever else will listen. |
How I resolved the issue
I suggested to my boss this morning that I take a smaller vehicle since I was only picking up one drum of spent latex paint (turned out to be about 15 gallons) and we didn't need to use a truck with a GVWR of 32,900 lbs because of the motor fuel tax issue. (Don't ask!!!) :? :roll:
He had no problem with it but it turned out that the little trucks with tail gates were scheduled to be used so it was back to the bigger truck. I wrote a statement in my log book for my boss to sign before I left. It said something to the effect of "I know it is illegal to operate in New Jersey with this truck without a motor fuel tax permit and I caused the vehicle to be operated in that jurisdiction anyway." He did not sign it and asked why I was making a big deal of this. I told him that if it was no big deal that he should sign the statement. I ended up going in a vehicle with no tailgate (turned out to be no big deal) that had a GVWR of about 10,700 and it had a D.O.T. number. The truck was not quite up to snuff but I was unable to site a section number pertaining to what is acceptable for a back door. I think it is best that when one butts heads with a boss, he better be right. Hopefully I won't have to take that truck again or I'll have to look it up. :roll: :roll: By the way, this thread may be better suited to go in the Rules and Regulations area. I started this directly in a search and I was in the Owner Operator area. |
Re: How I resolved the issue
Way to stick to your guns. I'm proud of ya. :wink:
if one does not have IFTA, you need fuel permits for each state that you would run in for the trip. buy these thru a service, vendor station , a scale house or POE.
Rev,
The door has a hole I can put my fist through. The door closes okay and the latch works. I strapped in the 90 pound drum and I think that set up would be able to withstand a force of the required 2 G's (if I remember that correctly). I don't recall any law (yet) forbidding one to drive a vehicle if it looks like a piece of junk. If I had gotten stopped, the inspectors probably would have gone over it truck with a fine tooth comb. I'm looking for a new employer but I'm also looking to move off Long Island to PA in about 6 months. By the way, section 398 seems to be about migrant workers. If one reads that section alone, he would conclude that all trucks must stop at railroad crossings. It is strange that there is a section specifically for migrant workers. |
