Dashboard problem
The engine fluild indicator in the dashboard will not cut when u start the truck what's wrong
Not enough engine fluid? Bad sensor? Bad wiring?
BTW - thanks for all the fantastic info. It made the diagnosis of the problem so much easier. |
Originally Posted by Malaki86
(Post 526835)
BTW - thanks for all the fantastic info. It made the diagnosis of the problem so much easier. thanks |
Probably bad wiring in the dash, then, if all that stuff is out.
What in the world is engine fluid?
Antifreeze? |
| All times are GMT -12. The time now is 03:12 AM. |
