Basic Tools?
I was told to bring the basic tools for pre trip inspections. Other than a wrench, what would those "other tools" be??
Thank you for any help :D |
A "basic" tool kit for a driver would consist of:
1 quality 6 inch adjustable wrench 1 12-18 inch pry bar 1 hammer 1 dual chuck tire gauge able to measure up to 120 psi min. I roll duct tape 1 multi bit screw driver or a slot, phillips and a few different sized torx screw drivers. 1. Flash light with spare batteries 1. 100 foot tape measure |
I would add a decent socket set. Makes replacing mud flaps a lot easier.
Thank You both! :D
Forgot one thing that comes in handy. Vice grips.
Always carry a spare flux capacitor, might catch something on the pre-trip that requires a new one.
Sure, I can deliver that load yesterday. No problem.
Good leather gloves.
6" plastic ruler to check slack adjusters. 3/8 open end/box wrench to adjust brakes, if your company trains and qualifies you as a "Brake Inspector". |
Don't forget the KY. :P
http://i97.photobucket.com/albums/l2...10/4954497.gif
Cinnamon flavored tooth pick. An attitude, and a coffee mug. If it doesn't move enough...WD-40. If it moves too much..........Duct Tape. |
Yall are nutz. :lol:
roadhog, if it needs new wiring, baling wire. :lol: :P |
the basics for pretrip... be like a lot of drivers .. just a pen & your log book to just check off everything is in working order.. thats it!! :lol:
Pardon my ignorance but what exactly is a flux capacitor? :?
a flux capacitor only works if it has the 1.21 jigawatts needed for optimum performance. but be warned when finally engaged, you will then be in the time cuntinuum, wich would put you in limbo as far as reality goes... hope this helps... :lol:
Ok I'll chime in here, not on the capacitor though. Here is my list of (what I can think of) tools I carry.
wrenches, adjustable, box & open end...1/2, 7/16, 9/16 big crow bar....equates to more leverage bunngee cords, black heavy ones screwdrivers with different bits, one big flathead screwdriver flashlight duct tape tape measure 3lb hammer flashlight bolts and nuts for landing gear handle bolt cutters vise grips, channel locks, & regular pliers wire cutters elec tape rope or strapping |
don't forget the riser grease..
| All times are GMT -12. The time now is 04:37 AM. |
