Its not that hard, belive it or not. You can drive it like an 8-speed if you really want, then adapt to splitting the uppers as needed.
If you drive a stick bug, think of it like this- 1,2,3 are normal, but lets say you have a 4, 4.5, 5, and 5.5 as well. So, lets say you are in 5th, and don't necessarily want/need 4th- well, you can go into 4.5 (in between 4 and 5) or you can still go into 4th if you desire. Its literally the flip of a button, and looks a LOT more intimidating than it seems. |
low/high ?
Do you always "have to" use low/high or just in the hills or different driving conditions- I live in the hills?? Or if you are going down freeway just stay on one side? huh will I confuse myself more by asking that? well see ahaha
Re: low/high ?
For example: Eaton discourages extended cruising in 8th low because that position sends the power through two sets of gears (0.73 overdrive in the main box and a 1.17 underdrive splitter gear) and having the transmission run through both gear sets can generate excessive heat. |
Re: low/high ?
Re: whoa
oh ok well Ill try it ... one day.
Thanks so much, for your time. Kelly and arm.
