13 speed transmission shift pattern
can someone tell me what it is? or know where a good picture is? thanks a
Re: 13 speed transmission shift pattern
oh THANK YOU SO MUCH!!!!!!!!!!!!!!!!!!!!!!!!!!
A MILLION THANKS!!
I ask because
I was looking on EBAY for a "plate" for a friend/gift and there is one that looked more like a 15 speed and the seller swears its a 13 spd. EATON he claims....a
Re: I ask because
You shifted it like this: DR1-DR2-DR3-DR4-DR5-(shift thumb switch from DR to low)-3-4-5 (range change)6-7-8-9-10 or DR1-DR2-DR3-(shift thumb switch from DD to low)-1-2-3-4-5 (range change) 6-7-8-9-10. This is similar to the way the Eaton 15 speed is shifted, except the 15 speed only has 12 progressive ratios, instead of 13. The 6613 went out of production about 20 years ago. The proper plate for a regular 13 speed would look like the one I posted above. It's interesting that Eaton chose to call it's 15 speed transmissions "15 speed" despite the fact that you could only truly get 12 speeds out of it. :lol: :lol: FWIW, Eaton used to use a 3 position splitter button for the 13 speed instead of the 2 position/range change that we're more familiar with today. The 3 positions were "Low", "Direct" and "Overdrive". The extra "low" position took place of the range change button. When you went from "Low" range to "High" range, you shifted the button from "Low" in 4th to "Direct" in 5th, then proceeded to split gears 5 through 8 shifting between "Direct" and "Overdrive". :shock: |
WHOA!
ALL THAT SHIFTEN WENT RIGHT OVER MY HEAD. But thanks so much for your knowledge and time to type it out. much appreciated!!a
Re: WHOA!
As I've only driven 9, and 10 speeds. What would be the benefit of a 13 speed, over a 10 speed?
Thank you very much for the explanation. As with anything, I guess it just requires practice.
you see a lot of heavy haulers running the 13 or 18 speed transmissions, i've hauled equipment in the past with 9, 10, and 13 speed transmissions, and the 13 just makes it a bit easier, especially with those really heavy loads, i don't know how to type it out to make sense, it just works better :D
13 spd adds a few pounds to the overall weight but is well worth it.
By allowing you to split gears, its easier on the drivetrain and can save mpg when used righ by selecting a more appropriate gear. |
oj- LIKE OJ SIMPSON NO!!!!
FOR previous reply
DO you mean OJ SIMPSON? He drove truck?? No way. I know he DID IT!! Or is that what you mean?? a |
Re: oj- LIKE OJ SIMPSON NO!!!!
Its a random nothingness, its not meant to reflect a strong personal belief :) But, C'mon, who writes a book about how you would kill your ex? :lol: |
OH OK ....THOUGHT YOU MEANT
THAT HE DROVE TRUCK. IMPOSSIBLE. DONT EVEN GET ME STARTED ON THAT BIG *^%^#*&( JERK!!!!
MY BROTHER LIVES IN IDAHO SAW THE ONE ATTORNEY THAT QUIT AND SPLIT TOWN AFTER IT WAS ALL SAID AND DONE (FORGOT HIS NAME- MARK? ) AND MY brother walked up to him and said We all know OJ did it and the guy notted his head yes and walked away...huh . How does he sleep at night. ? HES a jerk too!!! |
Re: I ask because
Birken |
PackRat and Birken....did you ever drive the 5 & 4's?? They were common in Mack's...way back when..but International, Ken and Pete all used them as well. I drove an International in 80 that was set up with a 5 & 4 with a 2-speed browning in the back...great old wench truck.....used the 5 & $ for powering the main wench..with the 2 speed in neutral. Pulled many a piece of equipment out of the mud with it.
:rock: |
Re: I ask because
In those working conditions, and with the limited horsepower those old trucks had, you got good at split shifting the quad box with 2 hands real quick, cause the operating range of the engine was 1500 to 2100 rpm's,and you could not lug those engines down or they'd self destruct. After a little practice I got so I could do 2 hand downshifts & upshifts just as smooth as an automatic. Actually that's where the screen name "Splitshifter" came from - it was my CB handle back in the 70's. IMHO, the quadruplex was the greatest transmission ever produced. It's too bad that Mack didn't see fit to design a triple countershaft version of it to handle the high torque of todays engines. If I had a choice of driving a truck with a "modern" transmission (9, 10, 13, or 18 speed Fuller), or a truck with a quadruplex 5x4, I'd take the quadruplex anyday. 8) |
can you explain.....
I know you can with all your knowledge...
JUST -by LOOKING at the pattern (pictured) of the eaton 13 speed, it doesnt look as if you GET 13 spds, please explain so my girly friend can sleep at night. thanks a |
Re: can you explain.....
Add to that gears 1-4 on the plus the "Low" gear, you get 13 total speeds. It's actually more of a 12+1 transmission. |
ok well....
this isnt Arm, this is the friend asking...
I dont drive but I was wondering how you get to the high 5,6,7,8 once you click over to reg 5,6,7, ? my friend says its for different road conditions is when you use it. But confused about how to get to "high" once you shift over. I guess if I drove I would understand??? Kelly |
Re: ok well....
http://i16.ebayimg.com/03/i/06/9d/7c/19_1.JPG Push it forward to split from low to high. Push it rearward to split from high to low. When you split the gears, you don't shift the lever, just use the splitter button. However, in a 13 speed, the splitter button needs to be in low before you range shift into low range (gears 1-4). |
say if you are already thru all the gears why do you split? maybe that is where Im lost. What is the other switch on that knob (black one) ? Kelly
On the low side, you have a 5 speed pattern, where 1st is low gear. When you split to high you are using a 4 speed pattern and don't use the low gear position again. So you have 1 - 5 on the low side. 4 gears in direct. 4 gears in overdrive. For a grand total of 13 forward gears! |
The black switch is the Low - High range selector. The red thumb switch is the direct - overdrive selector. When you shift through the 5 low gears, you then raise the black range selector then start shifting the same 5 speed pattern but you forget the 1st gear slot and instead use the second gear slot, now this will be 6Th gear. when you shift to 7Th you simply move the red selector to the right. Now to go to 8Th, shift the gearshift straight down and at the same time move the red selector to the left and repeat this action. Its harder in IMO to tell you how to do this, than it is to do it...lol Look at the plate picture the other poster posted it will show you exactly how to shift this transmission. |
Ok lets start with a typical 9 speed.
Start in low, making sure the range change switch, the larger black one, is in the down position, or low. Shift lever to 1st, Shift lever to second, Shift lever to third, shift lever to 4th, and just before you shift again, you pull the range change switch to the high position, then shift into the 1st position again, which is now 5th, then shift to 6th, then to 7th, and finally to 8th. While it's called a 9 speed it's more like an 8 speed plus low. Now with a 13 speed. Start in low, making sure the range change switch is in the low position and the red splitter button is in the rearward position. Shift lever to 1st, Shift lever to second, Shift lever to third, shift lever to 4th, and just before you shift again, you pull the range change switch, the larger black one to the high position, then shift into the 1st position again, which is now 5th. With the red button in the rearward position, you are in 5th low. To get 5th high, you move the red button forward, release the accelerator and let the RPM's match until it shifts into 5th high. Before shifting into 6th, move the red button to the rear and move the lever into 6th, this is now 6th low. To get 6th high, you move the button forward, release the accelerator and let the rpms match until it shifts into 6th high. Before shifting into 7th, move the red button to the rear and move the lever into 7th. this is now 7th low. To get 7th high, you move the button forward, release the accelerator and let the rpms match until it shifts into 7th high. Before shifting into 8th, move the red button to the rear and move the lever into into 8th, this is now 8th low. To get 8th high, you move the button forward, release the accelerator and let the rpms match until it shifts into 8th high. You DON'T move the shift lever to shift betwen the 5-8 low and high gears, you shift with the splitter button. Thats how you get 13 speeds. |
Why confuse him with the 8 +1 and the 12 + 1!
These transmissions are 13 and 9 forward gears! |
whoa
WOW, im sticking with my vw bug. My boyfirend was going to try to teach me but im not that excited about it now. that looks crazy !! thanks for leting me try to comprehend it though very nice teachers.!!!KELLY
Its not that hard, belive it or not. You can drive it like an 8-speed if you really want, then adapt to splitting the uppers as needed.
If you drive a stick bug, think of it like this- 1,2,3 are normal, but lets say you have a 4, 4.5, 5, and 5.5 as well. So, lets say you are in 5th, and don't necessarily want/need 4th- well, you can go into 4.5 (in between 4 and 5) or you can still go into 4th if you desire. Its literally the flip of a button, and looks a LOT more intimidating than it seems. |
low/high ?
Do you always "have to" use low/high or just in the hills or different driving conditions- I live in the hills?? Or if you are going down freeway just stay on one side? huh will I confuse myself more by asking that? well see ahaha
Re: low/high ?
For example: Eaton discourages extended cruising in 8th low because that position sends the power through two sets of gears (0.73 overdrive in the main box and a 1.17 underdrive splitter gear) and having the transmission run through both gear sets can generate excessive heat. |
Re: low/high ?
Re: whoa
oh ok well Ill try it ... one day.
Thanks so much, for your time. Kelly and arm.
