golfhobo |
03-19-2007 01:39 PM |
Originally Posted by driver67373
One big factor today is the rising cost of diesel fuel. Controlling fuel cost is a critical part of being successful in today's market. Speed is the biggest factor in getting good fuel milage. A company with a large fleet that can increase its average mpg just by 1 mpg can save millions. It's not about being greedy, it's about using common sense.
I can't quite agree with this. My company recently turned down all our trucks, and I'm pretty sure they're about to see that it has cost them money.
I'm no great mechanic, but I'm pretty sure that a small amount of fuel is burned with EACH revolution or the engine. If so.... figure the amount of fuel burned at 1300 rpms over an hour versus the amount burned by 1800 rpms over the same hour. Now multiply by many, many hours, and the number of trucks you run.
My truck USED to have enough power to maintain a speed of 70mph or so, going UP many hills and over ALL slightly inclined grades - in 10th gear - fully loaded.
Now, with the slightest increase in grade, I have to downshift to 9th, the rev limiter drags me down to 60mph or lower and I spend a LONGER period of time going the same distance, at approx 400 MORE rpm over that timeframe.
Can someone explain to me how I'm NOT burning more fuel at those times? And those times are now a constant part of my day.
Your theory might hold true for AUTOMOBILES, who don't use a different gear to maintain highway or top end speeds. But, I don't think it will hold true when you put a 40,000 lb monkey on your back. :wink:
