-   Amusing Truck Driving Factual Stories (https://www.classadrivers.com/forum/amusing-truck-driving-factual-stories-23/)
-   -   What is the highest speed you've got your rig up to? (https://www.classadrivers.com/forum/amusing-truck-driving-factual-stories/22013-what-highest-speed-youve-got-your-rig-up.html)
Scout 04-26-2007 06:34 AM
Originally Posted by mozzi
One has to have SOME (even a little) understanding of physics here to understand what I’m about to explain.
Ever seen a dragster being launched off of the starting line…?
What happens… ? The front of the car lifts up off of the ground… he pulls a “wheelie”. Right ! What’s actually happening here though ?
We’re talking about torque. As the engine produces power or force… this force is transferred through the driveline to the axle. As the force to the axle is increased the weight (or downward pressure) on the steer tires is decreased. This happens with every vehicle… EVERY VEHICLE.
In a truck traveling down the highway, the amount of downward pressure on the steer axle is less while the vehicle is in an “ACCELERATION” mode than if it were sitting still. That same pressure would be “MORE” while in the “DECELERATION” mode which explains why your nose dips down when you hit the brakes. The faster the truck is accelerating, the lighter the pressure on the steer axle. At high speeds the steer axle is actually floating on the road… this effect is what causes “HYDROPLANING” on wet pavement.
If a driver is aware of this concept… while a steer tire blows… he need only apply the trailer brakes gently (PROVIDED HE/SHE HAS A TROLLY BAR) to keep the front end of his/her tractor “UP” while decreasing the vehicles speed.
Now you can say what you want too but, when I’m doing something that I think might be a bit risky… I want to know how to reduce the risk as much as possible
I have to disagree with this.
Originally Posted by Wikipedia
In automobiles, weight transfer (often confused with load transfer) refers to the redistribution of weight supported by each tire during acceleration (both longitudinal and lateral). This includes braking, or deceleration (which can be viewed as acceleration at a negative rate). Weight transfer is a crucial concept in understanding vehicle dynamics.
Weight transfer occurs as the vehicle's center of gravity (CoG) shifts during automotive maneuvers. Acceleration causes the sprung mass to rotate about a geometric axis resulting in relocation of the CoG. Front-back weight transfer is proportional to the ratio of the center of gravity height to the vehicle's wheelbase, and side-to-side weight transfer (summed over front and rear) is proportional to the ratio of the center of gravity height to the vehicle's track.
There's no way you can slow a vehicle while keeping "the front end of his/her tractor “UP”. Google "weight transfer" and there are several good articles.
mozzi 04-26-2007 01:06 PM
Hey Scout...
Your wrong.... Just plain wrong.
For starters, a tractor trailer is not an automobile. When will you rookies realize this ?
Secondly, GOOGLE doesn't know S&*t about weight transfer in a tractor trailer.
I have personally seen (with my own eyes) my own steer tire fly past my mirror and window on the drivers side. There was nothing whatsoever to indicate that the tire was flat or even completely seperated from the rim until I let off the foot feet (Gas pedal for you rookies) at which point the nose settled down and the left side dipped down. At this point, the left steer rim hit the pavement and I was absolutely positive that the tire that I had wittnessed flying by my window was mine.
So you can't tell me that I'm wrong.... you just depend on your GOOGLE to tell you about life and I'll go on living it and learning by EXPERIENCE.
Rev.Vassago 04-26-2007 02:06 PM
Rev.vassago:
Sir, aren’t you a bit arrogant…. maybe a bit hipicritical even ?
hypocritical :roll:
And no, I'm not. If you disagree, prove me wrong. :roll:
Arrogant? Sure. Who cares? What's your point?
Runaway ramps are for ANYONE who has trouble on the grade… whether it be an idiot who thinks that he’s indestructible or a driver who’s equipment has failed him (or her). Equipment failures are unfortunate (and many avoidable) but they do happen.
Your point? What does the above drivel have to do with a thread about how fast people have gotten their trucks up to?
The more I read of your posts… the more I doubt that you can even drive a truck.
Luckily, I could care less what you think. Your 25 million miles is irrelevant.
jiptwoo 05-21-2007 01:25 PM
post
Mozzi, you have a great memory and my hat is off to you; ---jiptwoo.
Phantom433a 06-01-2007 06:22 PM
Originally Posted by ironeagle2006
Also I did not get my CDL from a driver mill I got mine the old fashion way MY FATHER sitting in the jump seat training me when I screwed up he let me know.
Yea.... I bet he did the same to you that mine did to me when I did something wrong.....slapped the S**T out of me and exclaimed "this is MY truck....you break it and YOU can make the payments." Swift is great at taking a driver with 6 months wheel time and making them trainers.
The fastest I've gotten my truck up to....its governed.....75....thats the top speed here in Az, where I run the northern part.
GI_James 07-24-2007 04:21 PM
Re: What is the highest speed you've got your rig up to?
Originally Posted by zz4guy
I was doing 100 in my camaro yesterday and it got me thinking - what would it be like to have an 80,000 lbs rig going that fast?? :shock:
Post your stories and locations of where you hit the speed.
I had a military Armored 5 ton almost to 60 mph...
ladykatrina 07-29-2007 09:45 AM
what a fun read this whole thread was, guys,thank you for all the free amusement! :D
Scout 11-17-2007 02:46 AM
Hey Scout...
OK then, what was holding the wheel up in the air while the tire was passing you? Even bobtail you've got a good 10,000 on the steer axle, and you're telling me that 5k was just floating above the road waitng for you to brake? I don't believe it.
Fredog 11-17-2007 08:18 AM
240 mph
but it was on a computer game
Fredog 11-17-2007 08:20 AM
[quote="Rev.Vassago"]
39 months total time OTR driving I was not a 6 month wonder. Also I did not get my CDL from a driver mill I got mine the old fashion way MY FATHER sitting in the jump seat training me when I screwed up he let me know.
Something stinks here, and it ain't me.
Forced off OTR driver with 1 million miles accident free name the commidity I pulled it. Dead bodies?
/quote]
1,000,000 miles / 39 months = 25,641 miles per month. Care to explain how you managed that? :roll:
I smell B.S.
