Originally Posted by Glad Hand
(Post 476137)
Hell, I've been using vice grips with success for years. Pull the lever out as far as it will go. Catch a bite with the vice grips. Rock the truck. Pull the lever out a little further. Catch another bite. Rock the Truck. Continue until the pin unlocks. Works for me.
Just picking on you! :) |
I have fought those straight bar tandem releases for years.
The ones that have the lever lifts are the best. You just go back there pull up on it and 99% of the time the pins just pop right out and the lever goes all the way up. If they don't release just pull up on the lever go back to the truck and rock it one time gently then go back and it raises....no problem. I've never had 1 ounce of problems out of the lever lift releases. If I purchase a trailer it will have that type of release on it or I won't be a buyer. |
Originally Posted by Dave_0755
(Post 478363)
The ones that have the lever lifts are the best. You just go back there pull up on it and 99% of the time the pins just pop right out and the lever goes all the way up. If they don't release just pull up on the lever go back to the truck and rock it one time gently then go back and it raises....no problem. I've never had 1 ounce of problems out of the lever lift releases. If I purchase a trailer it will have that type of release on it or I won't be a buyer. But, try sliding tandems when one of the pins is disconnected from the pull mechanism.:eek1: |
(Post 478363)
Originally Posted by AsphaltVoyager
(Post 482154)
Better yet, get the trailers with the hydraulic pin releases. They work a trick, lemme tell ya. ;)
I also use the vise-grips on trailers without the air-release, but I also use a company-issued pin-puller to help pull the handle out on the older trailers. I rarely run into problems with that method. |
| All times are GMT -12. The time now is 01:51 AM. |
