Uturn2001 |
04-15-2008 03:52 PM |
Originally Posted by mikeymike
I have been eyeing those thermo-electric coolers at Pilot. I have a lug up that i got from walmart that just slightly cools. I was wondering if the ones at Pilot work any better? Any help or info. would be greatly appreciated...
I have owned Coleman and Igloo 12v coolers and have never had a problem with either one cooling quite well.
I do not know where you have yours set up at, or exactly how you are using it but here are some tips/info:
If the items are warm or only slightly cool when you put them in your cooler, and if the cooler is shut off or has only been recently plugged in it can take 12+ hours to really cool those items down.
To get the best cooling the cooler should be kept out of direct sunlight and there needs to be at least `1 inch of air flow around it. Also make sure that there is not any heater ducts blowing on it. Remember that these 12v coolers will only cool 35-40 degrees below what it percieves as the surrounding air temp.
To help them cool faster and to stay cool longer when you unplug it and to be a bit colder when in use put a small (20 oz) bottle of water or use two or three ziplock sandwich bags, one inside the other, and fill with ice. I suggest the latter if you are on the road for more than a week at a time as you can refill the baggy.
I have actually frozen water in them several times.
