Dashboard light replacement
I have a 2006 International 9400i and I need to replace some burnt out lights bulbs in the dashboard gage. Anyone knows how to get to the light bulb?
Originally Posted by sepmaret11
(Post 725606)
Three screws under the steering column, pop the plastic cowling off the steering column, pull the dash cowling towards you carefully but with some force to pop it out the clips, undo the screws in the corners of the dials, unplug the three connectors. Replace the 4 main dial bulbs in the twist-lock connectors with T10 LEDs.
I work as a courier for a company, and I have to use my transport to move all kinds of merchandise. My dashboard lights are off, it can make my job uncomfortable and dangerous. I ordered parts from a local site that car parts same day delivery, and I am glad that after the purchase I can work normally. I can see how fast I’m driving on the road, and I don’t get a ticket.
You can visit your local car repair shop to fix the problem with your dashboard light. I am sure that they can recondition the old one. If it is not possible, you can buy some bulbs from https://www.vont.com/product/smart-s...-strip-lights/. I always buy everything related to car lights from this website. They have very qualitative light bulbs. Recently I bought from them RGB lights for the interior of my car. They make my car's interior look way better than it was without them.
I’d suggest you get new LED light bulbs instead of incandescent ones because LEDs have a much longer lifespan. You will bother much less changing them all the time.
I understand your situation with the burnt-out dashboard light bulbs. To access and replace these bulbs in your 2006 International 9400i, you might need to remove the dashboard panel. I had a similar issue with my truck's gauges, and I found a helpful guide on a trucking forum. Additionally, you can also check out simpletire online resources for any relevant tutorials that might guide you through the process.
| All times are GMT -12. The time now is 05:42 PM. |
