clunking in the transmition?
i have a eaton fuller 10 speed in my Columbia. when I'm heavy and only in 1st and reverse when I go to take off if I take off too had I get a clunk in the stick and the stick goes over.. now, all motor mounts and tranny mounts are fine. it is "sweating" pretty good but I don't want to pull it until I need to.
Clunking in the transmission is never good. Have you checked your transmission fluid? I had a problem with my transmission not long ago. Turns out there was no fluid in it. Where I have had it serviced they apparently never checked the fluid. In your situation, it could be several things. If the fluid is ok, my guess is that you will need to get into the transmission. BUMMER!!!!
Originally Posted by GMAN
(Post 535298)
Hopefully, you won't need to pull the transmission to find the problem. If it is leaking, then you may need to pull it to stop the leak. If so, it would be a good time to open it up and have a look. It won't cost much more to check it out once it is out of the truck.
Sometimes its the rear end, those type of clunking noises can be tough to find sometimes, and they can be in strange places too
The mechanic had to ride on my deck plate in the yard to figure mine out, it turned out to be the power divider |
Originally Posted by Maniac
(Post 535322)
| All times are GMT -12. The time now is 06:10 AM. |
