-   -   Just a frame and running gear needed (https://www.classadrivers.com/forum/truck-maintenance/45333-just-frame-running-gear-needed.html)
Boston 05-16-2015 12:22 PM
1 Attachment(s)
Hi. I'm exploring an idea for an RV. More like a tiny home actually but built on a < 40' drop deck trailer. What I'm hoping for is some advise on which manufacturer will work with me on a unit without the deck on it. I only need the frame with the plate connector, the rolling assembly, brakes and a few other things.
Thanks folks
Dan
[ATTACH=CONFIG]1444[/ATTACH]
Brucesmith 05-16-2015 12:43 PM
Why would you want to build an RV on that heavy frame? It's going to be a heavy pig that will not be allowed in many campgrounds. What are you using for a tractor? I hate to burst your balloon but it will turn into something expensive and strange. There are companies that custom build 5th wheel RV's. If you ever wanted to sell it I finding a buyer. would prove difficult. Your attachment does not work???
Boston 05-16-2015 12:57 PM
1 Attachment(s)
well thats why I was hoping to find someone who'd work with me a little on the frame. I don't need anything all that heavy but its likely to be more than what a dually could handle. Although the dually would be cheaper to insure. and yes likely more camp ground friendly. I wasn't thinking to much about campgrounds though. I was thinking more like tiny home style.
http://clv.h-cdn.co/assets/cm/15/10/...-edit1-lgn.jpg
https://www.google.com/url?sa=i&rct=...31912130892739
classictruckman 12-01-2015 08:01 AM
If you're worried about weight you should look into a company that builds aluminum trailers.
