-   -   Parking Brake Indicator Light on Dash Stays On (https://www.classadrivers.com/forum/truck-maintenance/45274-parking-brake-indicator-light-dash-stays.html)
Midliner_CS300 04-03-2015 08:46 AM
1991 Mack Midliner CS300
Inside the cab on the dash I have two indicator lights for the air brake system.
1." BRAKE " indicator light - comes on until air builds up to over 60 psi then this light and the buzzer goes off.
2. " P " parking brake indicator light comes on when you pull up the yellow valve knob for the parking brake.
Recently , the " P " indicator light is always on , even when yellow knob is pushed in.
When yellow knob is pushed in , the brakes do NOT grab , truck roles freely as it should.
Air system goes to 110 psi as it should
With parking brake OFF the brake canisters are operating as they should - fully retract into canisters
Brake fluid reservoir ... is full , this is for the hydraulic clutch I believe ??
Is there a relay somewhere that has gone bad causing this warning indicator light to stay on ?
The truck is operating normally aside from this warning light.
Any ideas ?
