night watcher |
10-04-2014 07:52 PM |
Lakeshore Truck Services Gary, IN very poor workmanship and overcharges
Lakeshore Truck Services is a truck repair shop in Gary Indiana.This shop has very poor workmanship and overcharges its customers. If you are in the area and are in need of truck repair , you may want to stay as far away away from this truck repair shop as you can get unless you have money to burn. I have had repair work done here on a few occasions and have regretted every experience I have had there. Shop will replace parts on your truck that do not need replacing without your authorization. Also they say that the per hour rate is 75.00 hr but will bill you 4 hrs for a two hr job and than when you get your truck back you will find that the repair job was not done right and will have to go elsewhere to have what they attempted to do corrected, so not only are you getting overcharged by lakeshore truck services and having parts replaced that you did not authorize but now you have to go elsewhere and have the botched work repaired correctly. I would advise any driver needing truck repair services not use lakeshore truck services in gary indiana. The mechanics are not trained but are just guys hired off the streets that do not know what they are doing and are not certified. STAY AWAY FROM LAKESHORE TRUCK SERVICES IN GARY,IN
