-   -   Tire size (https://www.classadrivers.com/forum/truck-maintenance/44963-tire-size.html)
solo379 10-04-2014 04:57 AM
Tire size
I've got 24.5 LP all around, and thinking about putting 11R24.5 on steers, due to better load rating. I'm always at the limit on steers. I couldn't see how it could go wrong, but just to make sure... What do you think, or know about this setup? Thanks!
GMAN 10-04-2014 12:00 PM
If you put tall rubber on the steers and LP on your drives, your front will be a little talker than your rear. I have a truck that came from the factory with 24.5 LP on the steers and 24.5 on the drives. The steers sit a little lower, but it seems to work alright. You should be able to find tires with a higher rating without increasing the tire size. I would first check to see what might be available in the same size that would have a higher rating. I know many dumps run tires that are rated at about 20,000 pounds.
