Originally Posted by Maniac
(Post 526960)
Found this........... http://www.classadrivers.com/forum/t...r-tandems.html
Originally Posted by Roadhog
(Post 526961)
I like to run the tandems all the way up and back several times, once in awhile to keep them working smooth.
I also adjust my brakes, which helps keep the frame from tweaking to one side. Some older reefers I pulled, were tweaked, and I'd use a hammer to nudge the pins loose on the side that stuck. You need WD-40 and duct tape, but if they don't work, I like to try a hammer. :) |
easier to have 3 or 4 axles like us then you dont have to move any haha
Mitch, if we brought one of your trucks up here... it would want to be upside down, on the wrong side of the road, all the time. :)
hell sometimes i wish i had a spread. but i thinki'd be going though tires a lot with the sharp turns and what not.
I have a trailer with the same problem. I bought the Sta-Rat pin pulling tool. It's spring loaded and puts constant pressure on the handle while you rock the trailer. When the pins get free the tool will pull them out. Google Sta-Rat. It works just like the video shows. For me it was worth the money.
tried the vice grips method-its works some of the time. but still to many trips in-n-out of the cab and back to the the trl. I read on one of these posts about using the short bungee chord trick - hook 3 or 4 straps to the handle and then the side of the trl and then rock the trl and it seems to work.
Originally Posted by ORPLINER
(Post 527128)
The surest solution is to buy your own trailer with "air slide" like I did. Problem solved! |
(Post 526960)
Keep tractor and trailer in straight line, rock trailer, pull pins. If that doesn't work use a small bungee cord to keep pressure on the pin release handle and use a small sledge hammer on the stuck pin...works every time.
| All times are GMT -12. The time now is 05:58 AM. |
