-   -   bunk heater core (https://www.classadrivers.com/forum/truck-maintenance/43783-bunk-heater-core.html)
firebird_1252 02-16-2013 09:26 AM
bunk heater core
anyone know how much of a pain it is to do in a 04 columbia? i dont see it leaking but when i put the heat on in the bunk the smell of coolent is ureal.
Dalor Logistics 02-16-2013 09:34 AM
Depends on what your level of "pain" is I guess, that's relative.
Passenger side , remove kick plate, behind there is a box with cover ,
remove 8 screws,
drain down coolant about 4 gals, remove hoses, at fire wall,
4 screws hold heater core in place, remove and pull out
(there may be some corner brackets too)
Good luck!
firebird_1252 02-16-2013 09:49 AM
the front seems fine, its the rear one i think is shot.
Dalor Logistics 02-16-2013 10:40 AM
There should be a panel/bed/bench that lifts up at the rear of cab to get to an access panel.
