-   -   fuel temp sensor (https://www.classadrivers.com/forum/truck-maintenance/39926-fuel-temp-sensor.html)
heavyhaulerss 05-13-2010 02:03 PM
fuel temp sensor
had yellow light come on dash (engine warning) found out it is fuel temp sensor. is it important to replace asap ? what affect will it have if not replaced. hope to finish my loads for the week. so far I have not noticed any difference in engine performance. also can I just replace myself or does it need to have anything reprogrammed into the ecm? called freightliner dealer. can order part & have in a day.
heavyhaulerss 05-13-2010 02:20 PM
This is on ser 60 det
bob h 05-14-2010 10:17 AM
It may affect fuel mileage. Check for a 2-wire sensor at the fuel filter header. Key switch off, you just thread it out and thread new one back in; if it was the problem, the light should go out when you key back on. Engine may start hard after if you lose too much fuel ( have the new one ready to plug the hole ).
heavyhaulerss 05-14-2010 11:17 PM
got the new sensor. dealer had in stock. location of sensor is on back of fuel pump. will change today. sat. I dont have the typical fule filters, so I am not sure about any fuel filter header. I have the davco sys.
thanks for the reply.
heavyhaulerss 05-17-2010 08:11 AM
That was one of the easiest fixes. 3/4 wrench. dripped about a tbls of diesel out & then stopped, screwed new sensor in.
