Antefreeze ,,leak''..pics included.
1 Attachment(s)
Pictures will explain it more easily but i have antifreeze leaking right out of some kind of a breather hose underneath my cab, passenger side right where all the AC lines go in....its leaking more in colder weather and it has been doing it for a while with no issues. Am not noticing that am loosing any coolant at all...its a DD60, 400K miles, 475hp.
What is this hose called and what is its purpose? |
1 Attachment(s)
Thats the hose am talking about right next to the AC lines..
1 Attachment(s)
The aftermath.....
sure looks like coolant leak in the core and it is coming out the condesation tube.
Do you have a heater core in there with the a/c condenser? It could be the core or a hose leaking when it's cold. I would check the hose clamps & core.
You need to wash your truck too. |
Hey, thanx.. Quote:
Places where we load at are about foot deep in all kinds of *****, from limestone to gypsum and clay. If i wash it today, itll be back to looking crappy tomorow. |
Yes, the heater core is in there along with the A/C evaporator.
Those 2 rubber 90 deg. lines with the spring type clamps on them are the coolant lines to the heater core. There is a leak in the heater core, or in the lines inside the HVAC unit and the leaked coolant is draining out the drain tube that is there to allow A/C condensation to drain out of the HVAC unit when using the A/C. You'll have to pull the lid off the HVAC unit inside the cab and have a look. . |
