air bags
is there a good way to keep my trailer air bags from stretching when unloading? I haul heavy single steel coils & I just noticed that I have 3 air bags leaking right at the bottom seam. I noticed this cause of all the rain water bubbling. the 3 that were leaking all all new.( installed within the last 6 months -3 years. the one original bag has no leaks yet. before buying all new bags. AGAIN... what can I do to keep the new ones from stretching until they rip also?
Chains between the frame and axle. You can also hook them shorter to use as a "lift" axle when MT.
Dump your suspension before unloading. Proper shock absorbers should NOT allow the bags to over-extend. |
Are the new bags the proper ones for that application?
It seems strange that the ancient "original" bag is still OK, but the 3 replacements are leaking. I agree that you should dump the air suspension before unloading. |
yes the bags are the correct replacement. I took the old one off & truckpro ran the numbers & gave me the original hendrickson bag. I relate the one not leaking to the same ole. (they dont make em like they used to). I have seen recently a lot of flat bedders with chains that appeared to be hooked in such a way. i dump my suspension valve. it is hooked up to my front axle. it does no good for the back. it would take too long to dump most of the air. I know I have wore out shocks. I guess i could chain the alxle to the frame, since it wont cost me anything & get new shocks on trailer & see if that is the problem. the chains I have seen recently are on newer trailer though & I would not think the shocks would be wore on newer equip. I also have noticed lately that my bags strech so much , that I wonder what has kept them in tact this long. maybe my shocks have worn completely out & that explains more stretching now than in the past. on chaining...I dont want to weld anything. would looping a chain around the axle to directly above around frame & leave limited slack work ?
My Wilson flat has nylon straps around the shocks to prevent over extension.
The shocks should "top out" before the airbags over-extend. If they don't they are the wrong shocks. Chains/straps prevent the shock from breaking when the axle suddenly drops down.
I set the height myself shen I replaced the leveling valve a while back. comapared to all others I have noticed, mine are not too high. mine are lower than most all I see. I have just put 1 chain on each axle to the frame, with just enough slack to the maximun height I want allowed. will be gettting new shocks & put them on this week. the shocks are original equip. thanks for all the advice.
so far the chains I installed are working very well containing the air bags to an acceptable level. thanks 4 all the advice
