Detroit Series 60 vs. Cummins N14??
I am looking at trucks and mainly looking at the engine that is reliable, easy to maintain, and inexpensive parts. No Kitty Cats for me. I have an RV with a Cummins b-Series and simple to work on since it is a 94 mechanical. The engine/ truck will be from the mid to late 90s.
What engine would those of you prefer and had experience with?? I see the injectors alone on the N14 are an arm and a leg. On my B-series Cummins they are expensive too. But how are the Detroits? I do LOVE the sound of the Series 60. Ahh hell I just love diesel sounds, but not Chevy or Ford. |
ser 60 det!!!!!
The Detroits I've driven spent a lot of time in the shop. They seemed to have an appetite for injectors, as that's what were (seemed like) constantly being replaced. For my own money, I won't buy a Detroit, because when I'm running my own truck, I need to be on the road, not in the shop.
The N-14+ (500 hp redhead) I owned had good power, and spent little time in the shop other than oil changes. Yes, I did have a couple of times that it cost me money, but replacing the original air compressor after 800K or replacing the clutch after 750K really doesn't mean there is a weakness in the engine. Yes, I did have to have a front main seal replaced once. By the time I got rid of it, it had over 900K on it. Come to think of it, I did have to replace one injector shortly after I got it. Many times, I've been sorry I don't have it anymore. Who knew how fuel prices were going to go down. Then again, with the EPA regs, maybe it's just as well I don't have it anymore. Compared to the Detroit that the company just got rid of, Just this year, it had been in the shop (and I was off work) a total of 9 weeks. It had 534K on it when they got rid of it. |
Was it an EGR detroit?
I'd avoid those like the plague. Anything EGR for that matter. |
I am just going by my 94 ser 60 1.5 mil & not even an inframe yet. injectors after 1 mil. factory cltuch til 1.1 mil, still org turbo still going everyday. burns & leaks a lil oil, but still has power. 11.1 h.p.
I have been around both engines for several years. The Detroits are pretty good engines overall. They will get better fuel mileage on average than an N-14, but the N-14 beats it out in torque and low RPM lugging power, and usually the engine brake is a lot stronger. Pittsburgh Power will tell you that the N-14 is a more solid engine, but that doesn't mean the Detroit is a slacker either. N-14's will tend to be a little pricier for parts than a Detroit. My choice would be for the N-14, but if the price were good, I would have no problem opting for a good Detroit.... specifically the 12.7 pre egr version. Very reliable engine and when matched with good tranny/rearend specs, really good mpg.
1997 S60 DDEC III 470 HP is the year the DD techs I know would own, if they were buying one for themselves.
Detroit! It's settled. No more opinions, other than detroit !!! This question is closed to other opinions!!
The N14 is the most awesome motor I've ever had. The last Detroit I drove ate its turbo after only 60K miles. The N14 could pull Mount Everest out of the ground without complaint. Even set far below its power threshold, I outran owner/ops uphill at 79,580(at least until 68mph). N14. There is no substitute. |
Well, a little over a year ago I had absolutely had it with that P.O.S. Turd of a 500 HP Detroit 12.7L. It was a 1997 model. Yanked it out of my truck and dumped it outside after 71,000 miles on a major inframe. Shoveled in a N-14 Red Top 525 HP and absolutely love my truck. LOVE IT. That Detroit was a turd from day one. This Cummins will run all over it. Won't quite get the fuel mileage the Detroit did, but at least I don't have to work on the damn thing. You will have to replace some N-14 injectors now and then. If you have some shop do it on the road, its expensive. But I have my local injector shop do them for about $90 a piece and I do the R&R.
What went wrong with your detroit? My dad had around 1.5 million miles before the inframe, and the only reason that was done was because the coolant wasn't being changed regularly. Ate a hole through the liner.
Other then that it was a fantastic motor, only other problem is it started rough in winter. |
My head gasket gave way on cylinder#5 even though the truck has 340K miles on it. Where the damage occured there was a little scrach on the head as well so the guys at Detroit Diesel changed the head too even though they didnt have to they said, didnt want to take any chances. It was all warranty so my cost was minimal but if it wasn't it would have been right there at about 4K....
I had to change my water pump and my starter so far. Everything so far ran me about 1200 for three years since i bought it new. I wouldnt know what to recomend, all these newer trucks are junk in my opinion but what choice do we have? I bought that pre EGR engine and I am gonna run it into the ground and even do a overhaul after a while....What i am not doing is buying another ,,new'' truck...or newer for that matter.. |
I would react the same way based on my bad or good experience with something. I know the det's w/ the 500 hp were blowing turbo's like crazy. mine was mfg in 94' titled in 95' 11.1 60 ser & still going well over a mil miles. in cold weather is does shake rattle knock & cough before starting, but after a couple minutes it is fine. my ole dispatcher bought a 200 pete w/ a n-14 cummins red top & after putting a few thousand in new tires, alignment, e.t.c it blew a rod ride thru the side of the block in g.r. MI. I went back with him to haul his truck & trailer back home. as far as the newer engines, or trucks. I dont trust any of them like I do my own. after driving it for over 10 years, I know what to expect.
I did drive it 1.2 million miles. Kept losing head gaskets and no one could ever figure out why, not even me. I was an ASE Master Truck Tech for years. It used oil from day one - 1 gallon every 2,000 miles from new and even after the major overhaul. It never ran well - never pulled well and never got any better than 5.6 mpg. Over those miles, I had to replace 9 turbochargers and 2 reman heads and 7 head gaskets. It lost 2 head gaskets and 2 turbos in the first 100,000 miles and Detroit would do nothing about it. The big Cummins runs circles around the Detroit and gets 5.5 mpg doing it. I don't run 60 mph - ever, so it could be better. Most of my driving is 75 to 80 mph. |
My Detroit didnt ask any questions, they just got to work. |
N14 swap
All in all, it was an easy, direct swap. |
Cummins / Detroit swap
havn't had a problem with my detroit & it has egr.i get 6.5 mpg heavy 7.5-8 light
Cummins N14 & Detroit Series 60 both good engines
And on topic...Kinda "chicken and egg" question.... |
Both are good engines,,a plus with the N14 is you have 3 cylinder heads rather than one on the detroit,, N14 is cheaper to maintain,,both beat a CAT,,CATs are expensive to repair .Injector for the N14 are not too expensive,,my last N14 I replaced them at 900,000 miles and only because I had one go bad so I decided at 900,000 miles to go ahead and replace them all. Stay away from Volvos and Mecerdes,,you can get a detroit of cummins fixed anywhere not the sane with Volvo or Mercedes,,CAT parts are cost a lot more,,
Well, with the 500hp 12.7 pre-egr Detroits, you have to use a little more brainwave activity than the OEM seems to have. Before dropping in the rebuilt DDEC IV 500 hp engine I have now, we replaced the stock exhaust manifold with a ported/polished/coated one. We took off the stupid wastegate turbo and put on a larger Borg Warner 171702 non-wastegate turbo, and wrapped a turbo blanket around that. And we put Walker Megaflow mufflers on the stacks. We let that engine get rid of it's waste and b-r-e-a-t-h. For the intake side, we dumped the stock Donaldson and put on a Fleet Air Filter. Nice egt's, very good fuel mileage, and will walk with most everyone on the hills. Great looking oil samples and uses only about a quart of oil in 20,000 miles. Yep, quart, not gallon.
This one, along with a 1996 N-14 Celect I had at one time are the best engines I have ever dealt with. An ISX I had before this one really soured me on Cummins products. When it worked, it worked great. But when it had a hiccup, it was a wallet buster. Cummins is sure proud of their parts and price them pretty high. A VGT turbo for the ISX was $3600 (before core charge), just sitting on the parts counter, when I had to replace it. I put on the Borg Warner 171702 turbo on the Detroit for a whopping $689.... cost, shipping, everything, and no core charge. |
