Cant get Volvo started! D12 Engine Is there a way to prime?
Volvo with a D12 engine, ran out of fuel, just put some in but it doesn't want to start, any special priming needed?
Originally Posted by matcat
(Post 449496)
Originally Posted by Fredog
(Post 449497)
there should be a pump by the fuel filter, or take the filters off and fill them up. OR use ether which isnt too good on the engine
Haha I feel like a moron! I looked in the manual for the fuel filter changing procedure, thinking it would tell me how to prime it, well it does... There is a frickin electric priming switch right in the dash! I always wondered what that switch was for... now I know...
boy! that sure would come in handy, on my cat you have to pump until your arm gives out ( not that I ever ran out of fuel, I just heard that):smokin::smokin:
Apparently however I have to prime it more then once ;) It is a 4 min prime, and it got it sputtering, but not enough to start, and each button push is 4 minutes of priming, so I guess I will give it 3 good primes before I try again.
3 primes is what it took! She started right up, was rough for a few seconds but smoothed out.
Now I am upset I got all dirty messing with the fuel filter and I didnt have too! Didn't even have to get out of the cab.
(Post 449506)
(Post 449551)
experience is the best teacher. now you will never ever forget where the primer button is will you?
But you are right, I will forever now know how to prime a Volvo D12 and probably every other Volvo engine :) |
| All times are GMT -12. The time now is 08:00 PM. |
