I'll Bite!
That $9.99 12v pump has saved me a service call more than once, last time I think I was at a fuel island and the truck wouldn't start. My ISX has one of these visible, "glass" bowl fuel filters, and they can lose their prime. I've changed my fuel filter many times, but one time I just wasn't getting a good seal for some reason I know not why. So with the pump, you pressurize your fuel tank, loosen the cap on top of that bowl so the air escapes, and perhaps loosen the line going into the fuel pump so that air can escape there too- voila!!! A few bubbles here and there, tighten it back up, the prime is back! You can watch the fuel rising in the fuel filter housing as the pressure builds up. To hook up the air, I pull this lever under my cab that shuts off flow from one of my tanks. On the other, there's a drain tube coming off the top, the nozzle fits into that drain tube perfectly. I watched the service guys do it a couple of times, that's how I learned. |
I don't think anyone thought you were trying to be a jerk, I know I didn't. :thumbsup: |
I don’t carry an electric air pump, but I do carry 75 feet of air line fitted with a glad hand adapter and a quick release air chuck and blower. Also have one of those cheapo air blowers that attach to the seat air line. Not only is it good for blowing out the cab of the truck but it also is the only thing we’ve found that works as punishment for our cat. When he starts biting or clawing, all you have to do is lean down like your going to grab the blow gun and before you can get it in your hand he’s in back hiding under the covers. Won’t come out for at least 30 minutes after that. |
For those with the ISX that are disapointed with the fuel mileage, as I was, then you might give this a try....
On a COLD engine, turn the key on without starting, then wait at least 10-15 seconds then unplug the lower plug on the EGR. The ECM will close the valve during the wait time, then the unplug will leave it closed. Will usually only throw a code. Usually no check engine light or limp mode, depending on which truck the engine is in. The results? How about up to 1 mpg better fuel mileage. I did this some time ago. I have averaged about .8 mpg better than before I did this. The engine runs substantially cooler on hard pulls. No hp or torque gains that I can tell. Just that the engine runs smoother, less soot and smoke, and better mpg. Simple, cheap modificaton. Better than investing in the slew of addon stuff that normally doesn't seem to really work as advertised. |
'06 ISX... no DPF
'08 with a DPF here. Sorta wondering what the EGR trick will do to the DPF. HAven't found anyone that's tried it yet.
09 porstar. 450 hp isx, ultrashift. with 135k. been in the shop once "bad after-treatment injector and a pluged crankcase filter" hate the truck but love the isx. pulls better than the volvo d12, d13 and detroit d15, better jakes and better mpg.
...put less soot in it. |
