-   -   98 FLD120 Wipers (https://www.classadrivers.com/forum/truck-maintenance/36591-98-fld120-wipers.html)
cowdoc 12-27-2008 02:06 PM
98 FLD120 Wipers
My wipers take forever to start. I'm talking like 45 mins.. How can I check to see if it's the motor or the switch??? I use to be able to push the switch in and start them but that won't work now. Elementary I know but I'm an elementary mechanic . Any help will be appreciated.
Larry227 12-27-2008 02:39 PM
Turn the wiper switch on and check for power and ground at the motor. If you have both it's a bad motor. If you don't have power or ground you have a bad switch or an open or short in your wiring or a bad relay.
cowdoc 12-28-2008 01:25 AM
Thanks.
YerDaddy 12-29-2008 12:53 PM
Air or electric?
I just had to disassemble and clean and lube my Sprague HP135. Wipers were getting lazy.
cowdoc 12-30-2008 01:16 PM
Air. 2 lines coming out thru red button (trailer supply) bundle back of firewall.
Larry227 12-30-2008 05:26 PM
So much for my first suggestion. Take a line off at a motor and see if it's getting a good amount of air with the switch in the On position. If it is then you've eliminated the switch.
YerDaddy 12-31-2008 05:43 AM
Not sure why trailer supply would be hooked up to wipers.
Try what I did. Mine works alot smoother and easier.
I had to heat up the nut on the wiper arm to get it off.
Took motor all apart and cleaned every little hole with mineral spirits. Used O-ring lube for re-assembly. Manual says to use Dow Corning 200 (200wt). Vaseline would work in a pinch but will dry up in a year.
I checked my dash control knob too but it was fine.
I hope your air dryer is properly maintained because a contaminated air system will mess up more than your wipers. I hear trucks everyday where their air dryer is spitting every 20 seconds, meaning they have a major air leak and the compressor is cycling 100% of the time. That's messed up.
