-   -   Cat caught the FLU (https://www.classadrivers.com/forum/truck-maintenance/35048-cat-caught-flu.html)
allan5oh 09-14-2008 05:49 AM
yikes, good luck with that.
Kranky 09-14-2008 05:54 AM
Originally Posted by DragginMan
CRACKED HEAD!!
Why?
Was it operated in an overheated condition at some point?
DragginMan 09-15-2008 12:59 AM
Was told to drive it like it was for 4 weeks, so YES was driven overheated!! I can CRY CRY it NEEDS 2 BE LOOKED AT b4 something WORSE happens but....................BTW 815K, was told this is 3rd time major engine work. I have put only 70K on truck since getting job in late January, problem was surely present just didnt surface until recently.
NotSteve 09-15-2008 03:00 AM
I'm curious. Since your system was puking and it was a cracked head I'm assuming the overflow of coolant was then caused by diesel fuel mixing in. Didn't you smell it?
bob h 09-15-2008 11:47 AM
? the overflow of coolant is caused by compression from the combustion chamber... not diesel fuel.
DragginMan 09-17-2008 05:40 AM
What I noticed was the coolant flowing thru the overflow, and making note of the amount of coolant lost. Then I relay the situation to the higher ups. JOB DONE. They tell me what to do after that. "Drive it" they say. Sure, "but............". They said DRIVE. So I drive.
allan5oh 09-17-2008 05:53 AM
LOL
partssman 10-12-2008 01:14 AM
Originally Posted by bob h (Post 403878)
Sounds like compression leaking from the head gasket. .
We have about 7 O/O who run this engine and all but 2 we've already built with around 500,000 on them.
Cat has really pulled off the biggest turd of all time with the C15/C16. Thankfully they'll be out of the truck engine market in 2010 and begin selling International trucks under their name.
All of our problems started with a blown head gasket and then a few weeks later a complete inframe. We've talked about it and have come to a possible cause sitting around the break table......it's the Ultra Low Sulfur fuel is all we can come up with why the rash of Cat rebuilds. No problems til the fuel changed.
The ULS fuel burns hotter and with the lack of lubricating sulfur, the big yeller motor can't take it.
To give you an idea of the problem, everybody knows how much Paccar loved putting Cats in their trucks.......for the 09's they're pushing the ISX since Cat has so many problems. Seems one Pete dealer has 6 or 7 trucks they can't even get to run and the engineers from Cat say they don't know if they can make 'em run or not. Seems they took the 07 engine and added 23 more sensors as an emission fix and they puked.....
Sure would be nice to buy a new truck with with an ol four and a quarter in it :)
Kranky 10-12-2008 01:38 AM
Cat has really pulled off the biggest turd of all time with the C15/C16. :)
Where I work, we've got Cat C12's, C13's and C15's in Internationals.
The C12's and C13's are in quad axle dump trucks grossing 73K, and the C15's are in heavy haul tractors used for moving heavy equipment, permitted to 140K.
We haven't had a bit of trouble with any of them, except for a couple of rear crank seals on C13's which were covered under warranty.
The engines are 1999 to 2007 models.
:confused:
partssman 10-12-2008 08:42 AM
I'm sorry :D
Most of our problems are in Peterbilt 389's...2004 and 2005... and we haul furniture....go figure.
