humming noise
just today i noticed a humming noise coming right where the engine (isx 500) and the tranny comes together...sounds like a vacuum cleaner...
when i turn off the engine and restart it the humming would gradually come back on again... anybody with a solution would greatly be appreciated... |
Where the engine and transmission come together is where you are sitting. Is one of the voices in your head humming a tune? If not, does it make a difference how fast you go or if your are in a hard pull. Uphill, downhill is it the same all over?
i can't hear it inside the cab, only outside when i't's idling... funny thing is it disapears when i bump the idle to 1k... but when it just idles you can hear a distinct vacuum noise... everything sounds normal when i'm bobtailing or hauling... anyone with an isx 500 that sounds similar to that?? |
Re: humming noise
Remove the inspection cover from the bell housing. |
Re: humming noise
Remove the inspection cover from the bell housing.[/quote]
is there something in particular that i should look for??? thanks bob h... i was hoping that you would respond :lol: :lol: |
