-   -   Constantly blowing tires (https://www.classadrivers.com/forum/truck-maintenance/33609-constantly-blowing-tires.html)
BuickTurbo 04-23-2008 07:49 AM
We have a 52' race trailer with 2 sw tandems. It was designed for a single dragster and all of the nice features like a bathroom, toolchests and such.
We gutted it and now haul two 2700 lb cars.
The tires are 12R 22.5 - as I understand are usually used on busses and firetrucks. The trailer weighs about 25k dry, so about 36k loaded.
Pressures are set at 120 psi every morning at pre-trip and I see an average of 140-150 psi hot.
This company has had issues with this trailer blowing rubber way before I signed on. I thought it was wierd and due to lack of maintenance....until I took over. Had a blowout in Atlanta a couple of days ago, and now I see another tire starting to split.
The trailer is rated at 40K , the tires I believe to be rated at around 7390 lbs each.
So the tires allow about 30k total, my guess is it's overweight. Is 6K lbs enough to constantly blow rubber?
Double L 04-23-2008 07:54 AM
Are they recaps or virgins? If they are recaps then the heat is their worst enemy cause them to blow if too hot. Especially in the summer in extreme hot weather such as Texas or the southwest. With recaps if they get too hot they expand and the tread starts to peel and will eventually blow. That is why with recaps you should stop and let them cool but also with recaps they don't like to go any faster than 65 I think. Feel free to correct me if I'm wrong, it's been awhile since I talked about a mississippi tennis shoe (recap).
Bobby 04-23-2008 08:03 AM
That's a long trailer for only two axels IMO.
If your overloading those tire by that much that's the problem. Pull into the truck scales and they won't let you leave.
You have a liability to think about too, if their is a wreck because of a blow out and they find the trailer to be overloaded, They will throw the book at you.
Bobby 04-23-2008 08:07 AM
Edit: Is this a fifth wheel trailer ?
Bobby 04-23-2008 08:27 AM
Check the tire ratings and weigh it loaded to see what you have on them, then stay within their limits.
You can go to a heavier tire and rim if a bit wider tire isn't an issue.
If the tires are within their limits, check to see how old they are by the DOT code on the sidewall.
The last two digits will be the year of Mfg. and the two digits before that the week of that year.
It seems to me a 1200 22.5 rates higher than 7,320. ??
BuickTurbo 04-23-2008 08:41 AM
each tire's load rating is 7390.
Here's a newb question.
Is it best practice to bleed the tires back down to cold pressure after a couple of hours driving?
I have been through the scales in several states without issue. I guess for now I will back down to 65 for safety's sake. Believe me I don't mind being the slower truck.
I have been told that the tires on the trailer were bought new, but I dissagree. I will have virgin rubber before the next trip (Sunday).
I also have been informed that new tires had been put on before and she still lost one.
I sincerely appreciate the replies guys. My concern is the driving public as I am not hauling commodity.
yes, this is a fith wheel pulled by a Pete 387
Bobby 04-23-2008 09:02 AM
If the tires are running single @ 7,390 ratings and your hauling heavier by quite abit then that would be the problem IMO.
And no don't drop the pressure. You shoudn't have to worry about these tires failing.
My guess is they are old rubber, older than five years. Or you are overloading them. Even when you buy them new if they have been sitting along time in the tire shop, they still age.
Go to a private scale and see just what's on them. If your say 36000 lbs alot of that weight should be on the truck. But maybe the way the trailer is loaded there is too much weight on the trailer axels.
Edit: when you go to a private scale, weight the whole truck, pull forward then weigh the back axels on the trailer pull forward again and see what's on the farthest back axel only on the trailer.
And, or ? just weight the front axel on the truck if your curious.
BuickTurbo 04-23-2008 09:20 AM
Again, thanks for the help, advice, and comments.
One of the cars is directly on top of the drive axles of the tractor.
The other sits on top of the rear axles, but the weight of the car is in the rear.
This orientation was changed by me as the cars were then before placed on top of the rear trailer axles - one on top of the other. At one time both cars were on the upper rear deck......unacceptable to me as the trailer is fairly narrow and tall. So I changed it to over the tractor and over axles to spread it out.
We don't have all that much gear on board. A couple of tool boxes, pit stand (1000lbs), golf cart, and 5 small motorscooters.
Bobby 04-23-2008 09:27 AM
Maybe your close to solving the problem with the weight re-arranged.
I'll bet the tires were old even thought they had lot's of tread.
What kind of racing are you doing ?
BuickTurbo 04-23-2008 12:35 PM
http://www.ferrarichallenge.com/
We have 3 F430's in our camp. The field is about 40 cars. I haul 2 and the other driver had his own custom truck and trailer built. I will link you to some picks of the trucks side by side.
I hope we are figuring it out. I have two brand new tires coming tomorrow. This will make a complete set of new rubber.
Another thing we figured out is that the wheel wells on this particular trailer act like ovens - not a whole lotta flow through there being a single wheel. So I am going to make some intake ducts over the top of the wells to force air over the wheel assembly. I'm going to use our tire pyrometer and measure temps along the drive to Sonoma. I will close the vent and drive for an hour or so, record temps, open them up and do it again. This finally may be the culprit.
Double L 04-23-2008 01:24 PM
I wish you the best of luck!
Bobby 04-23-2008 01:36 PM
Yes, an enclosed tire with the lack of air flow isn't good. You might be able to do some research on acceptable tire temps for this type tire and load.
Isn't your Buick a V6 ?
BuickTurbo 04-23-2008 01:41 PM
http://www.texasstreetcars.com/viewtopic.php?t=953
Here's the link.
I have been trying to rebuild and refurbish that trailer since I hired on. We have a tight budget if you can fathom that. I can only do so much as the season is busy for me. Once in the off-season, she will be done right.
The red trailer is completely decked out in stainless inside. Satellite tv, internet, and streaming race data from the car. It also has an office inside.
It's pretty, but it only holds 2 cars.....mine holds 4 and we're there to race.
Yep....just a little V6. :lol:
solo379 04-23-2008 02:24 PM
Yes,..... if you want it to keep blowing. :wink:
Rated pressure, is the cold pressure only! You might need some readjustment tho, when seasonal temperature is changing (winter- summer).
BuickTurbo 04-23-2008 02:34 PM
Yeah...about the bleeding.
I contacted my old shop foreman and he read me the riot act about not touching a hot tire, unless it needed air after a cool down.
I was just curious as we do hot tire bleeding on our racecars. I KNOW...two completely different animals.
special k 04-24-2008 01:47 PM
I run 12/80R22.5's on my trailer singled out like yours. Our axle weight is around 13000 lbs. I run 16 ply Bridgestone R250's and don't have any issues. You could go to a 315/80R22.5 on a 9" wide rim or there is a actual coach wheel and rim that a lot of guys are running on their front axles. The tire is a Michelin XZE 365/70R22.5 and the rim is around 10" wide. Those last two sizes are good for about 16,000 to 18,000 lbs per axle.
BuickTurbo 04-24-2008 01:50 PM
Thanks for the info.
I cut the fender bolsters off the trailer today to open up the wheel wells. Hopefully this will let the area breathe a little more.
roadranger 04-26-2008 03:26 PM
The tire manufacturer should have a chart of proper air pressure for the actual load you have (once you get her scaled). For general use we usually run a fixed (high) pressure since it is too much trouble to set the pressure differently with different loads but in your case you should be able to set them for your actual weight and get better ride and wear from them. Also check to see if you can use 11R22.5's instead as I think the 12's generally have a lower speed rating and run hotter? Plus the 11's are the most common size. Four 11's are only good for about 24k total though - but it sounds like you are under that? For sure go through a truckstop scale and see where you are at on axle weights!
roadranger 04-26-2008 03:37 PM
Re: Constantly blowing tires
...about 36k loaded. [...] So the tires allow about 30k total, my guess is it's overweight. Is 6K lbs enough to constantly blow rubber?
Almost half your weight should be on the hitch and not on the trailer axles if you are using a fifth wheel hitch and a single axle dually tractor with at least a 20k rear - so you should only have about 20k on the trailer tandems!
DaveFromColorado 04-27-2008 02:39 AM
I knew someone that had this issue with an old 50' race trailer - he got tired of spending tons of money on tires and had a "friend of a friend" with an alignment shop check the alignment of the two axles to one another and found they were a couple degrees off, this caused some scrubbing of the tires which increased the heat a LOT ...
may not be the actual issue, but something to look into ... I don't know if the tires were ever "cupped" or not.
--Dave.
Orangetxguy 04-27-2008 11:57 AM
--Dave.
Best suggestion of the whole thread. The alignment shop at Kliens Truckstop in Fresno used to be really decent at trailer axle alignment.
BuickTurbo 04-29-2008 04:09 PM
Well, Some interesting info.
I used a tire pyrometer at every stop and I am getting consistent temperatures.
Running at 64/65 mph
1st 300 miles = 138 center of tread (all 4 tires)
95-110 on sidewalls
2nd 300 miles = (warmer part of the day) 138 center of tread
95-110 on sidewalls
The new tires were definitely an improvement. I could see out the rearviews that the tires were no longer bulging at ground contact, almost 90 degrees to the road surface.
The hot temps were in the 140-145 psi range. Which is about 10 psi less then before with the older tires.
Now that the tires will have the chance to cool off tonight, I will reset cold pressures in the am and take more temps for the finish run to Sonoma.
Thanks for all of the hints, advice, suggestions guys.
The alignment suggestion is a good one. I thought about that the other day. We will have a month off after this race and I will have time to have the alignment checked.
ps. Gotta love those Hwy 58 winds. Sheesh.
roadranger 04-29-2008 04:36 PM
Bridgestone sez normal temps are 150-180, anybody else out there have an opinion or observation as to OK temps? 180 seems a bit high to me? I usually "palm" the tires a couple times a day to see if they are all about the same, haven't burned myself yet!
Bobby 04-30-2008 12:17 PM
I would think if there was an alignment problem that tire or axel would run hotter if the tires were scuffing ?
Did you ever check to see how old the tires were that came off the trailer ?
BuickTurbo 05-03-2008 06:54 PM
Bobby,
They were from last season, so about a year old. I'm told that the replacements were usually used tires so there you go.
Now it's only new sneakers....and new only.
Bobby 05-03-2008 09:35 PM
Just remember how to read the DOT codes on all your tires ( Car or truck ) and you'll know just how old they are.
Good Luck
klleetrucking 05-04-2008 03:45 PM
Buick turbo
Mr. Turbo, I'm sure you've checked out what the other guys at your events are using on their haulers, what's their story?
How 'bout some pics of your race cars (please) and a pic of that BMF Buick you've got.
Good luck on the tire issues. Being a racecar guy you absolutley know that you use the best parts to get to the other end.
headborg 05-05-2008 01:15 PM
yeah, constantly blowing tires my wife out too.... :lol:
jroqueman 05-19-2008 12:47 PM
Ar there any abnormal wear patterns on your tires? I am running a mobile alignment business and that was my first thought. You should have your alignment checked. For the small price of having your trailer aligned properly, you just might take care of some of these issues. Your fuel mileage might increase as well if you are pulling a straight unit, vs one whose axles are fighting each other all of the time.
BuickTurbo 06-16-2008 08:11 AM
Sorry for the delay on reply.
This has been an interesting season so far. The tractor trailer is currently in Virginia getting a replacement hub on the rear forward left axle. Little smoke, little fire.
Most of the....let me take that back. ALL of the other race trailers have dual tandems. Most of those trailers have NACADUCTS to force air into the wheel cavity. No one is blowing on dual tandems.
I also came to the genius conclusion that the rims, being of a soild - non vented design are also a BIG part of the problem.
The tires (1 month old now) are not showing any abnormal wear. The alignment has been checked and she is true.
I also believe the heat trapped in the well caused the hub oil reservoir to melt. Fluid leaked out, bearing failed, got hot, fluid caught fire.
It wasn't a huge fire, just a nice quick billow. I pulled over and dusted it with the kidde.
Some things are going to have to change if I continue with this job. I truey love driving and would hate to go back to the old profession, but my safety and those around me are my primary concern. Not how fast and cheaply I get to the track.
WarHorse 06-16-2008 10:46 AM
Maybe the fire issue will push the powers that be towards listening to you. One can hope.
I love your avatar on Texas Street Cars. :) I can't find a pic of your Buick, though.
How the heck do you get 80+ hp out of each cylinder? :shock:
BuickTurbo 06-16-2008 10:52 AM
Well, the turbo is about the same size as the one found on the C15!
BuickTurbo 06-16-2008 10:54 AM
I will post pics as soon as I can figure out how. All forums seem to have different formats.
http://i244.photobucket.com/albums/g...stead08007.jpg
Here's the truck...i hope. All of the red has been removed as it was deemed "too busy" by all of us.[/img][/code]
BuickTurbo 06-16-2008 11:00 AM
Two of our cars, the close one before it was wrapped by Skinz.
http://i244.photobucket.com/albums/g...stead08001.jpg
BuickTurbo 06-16-2008 11:09 AM
Nice slow 12.1 pass on 20 psi.
http://i244.photobucket.com/albums/g...o/Capture1.jpg
Here's the trailer.
http://i244.photobucket.com/albums/g...stead08006.jpg
WarHorse 06-17-2008 12:11 PM
Ye gods! :lol:
Cool pix, thanks. I'll definitely holler if I see you on the road.
Orangetxguy 06-20-2008 03:30 AM
Ive seen that truck !!
BuickTurbo 06-22-2008 04:18 AM
We changed the picture on the back. We now have a pic of a 430 cruising on a back mountain road - super high resolution. It's nice, but the big problem now is that people take flash pictures of it while I'm driving at dusk. Freaks me out. Then when I pass a 4-wheeler they speed up to get a good look. Then I can't merge back over - really ticks me off, but I guess that's the price you pay.
