Trailer air valve
I just changed the air valve on my trailer and I think to much air going in the air bags because the trailer is higher/ 4-5 inch./ than other trailers.
Is there any option to fix the problem1 thanks John |
Yeah, adjust it to proper height, before you blow the airbags out.
Adjust the level sensor
all right, and where can I arrenge the hights because I can't find it on my trailer? where is that thing?
Thanks |
It will be frame mounted, with a rod of sorts going to one of the axles. Find a line on an airbag and follow it to the ride height valve.
What trailer air valve were you talking about? If its the in-dash valve, it would have absolutely nothing to do with the ride height. |
thanks guys I found it!
| All times are GMT -12. The time now is 07:20 AM. |
