-   -   Fuel Mileage (https://www.classadrivers.com/forum/truck-maintenance/32054-fuel-mileage.html)
ChikinTrucka 01-26-2008 09:35 AM
Fuel Mileage
Not sure if it's already been asked or what forum to use, but here it goes...
What fuel mileage are you getting from what truck? Engine? Gears? Trans? Etc?
I drive a 2005 Mack Vision and get between 4.5 and 5.5 MPG, mostly at 1800 RPM +/- and 70 MPH.
I know that really stinks and I'm wondering what truck/engine/trany/rears are the best combo for the best mileage.
Someone recently told me his 2006 Freightshaker gets 6 to 7.5 but he must keep the RPM's at 1650 to do it.
Thanks.
Double L 01-26-2008 09:38 AM
And the driver probably has a Detroit or Mercedes for power and you know how good on fuel they are.
tracer 01-30-2008 03:24 PM
Re: Fuel Mileage
Thanks.
2004 International 9400 with a wind deflector on the roof .. pulling 53" dry van. I have a 475 hp CAT with 1,650 lb/ft torque, 13 speed tranny with 0.73 top gear ratio, and 3.73 rears. I recently switched to low profile tires and I dropped a mile on the speedometer at the same RPM. I get decent fuel mileage (between 6 and 7 mpg) even fully loaded but only because I stay within the engine recommended RPMs. For my CAT, it's 1,300 to 1,400 RPM. I usually do 58 mph with a light load (1,300 rpm) and 60 mph with heavy load in hilly terrain (1,350 rpm).
1,800 rpm sounds too high even for a Mack engine... I'd suggest you found out your engine best RPM range, and maintain the road speed that puts you in that RPMs. You might need to get creative with axle ratios, tires (tall rubber will help you drive faster at better MPG), tranny top gear ratio, etc. But driving outside of your engine favorite "spot" is a sure way to waste tons of dough on diesel.
klleetrucking 01-30-2008 04:32 PM
Fuel milage
'03 379 Pete, 475/500 Cat, 18 speed, 355 rrs, flatbed. Coast to coast operation. 6.212 mpg since new. Down to 6.1 since low sulpher.
allan5oh 01-30-2008 06:18 PM
There's so many variables.
Driveline specs are about 20% of the factor.
A more efficient engine doesn't matter if the driver is doing 75 mph.
It's the total package:
- An aerodynamic truck AND trailer
- Low rolling resistance tires(super singles or XDA energy)
- Driven at less then 60 mph
- Eliminate idling
- With good specs for 60 mph(2.64's or 3.55's)
Will net you 7.5-8.5 mpg. That's not a joke.
bob h 01-31-2008 12:00 AM
quote="allan5oh"]There's so many variables.
*road speed is much less a factor than the resulting engine speed*
- Eliminate idling
Will net you 7.5-8.5 mpg. That's not a joke.[/quote]
solo379 01-31-2008 02:41 AM
http://i6.photobucket.com/albums/y213/solo3793/cat3.jpg
allan5oh 01-31-2008 03:55 AM
Are you saying that specs matter more then road speed?
I'd rather have an engine revving 100-200 rpm too high at 60 mph then spot on at 70.
Cummins fuel mileage paper states 4% difference from a perfect spec to a bad one.
Road speed makes many times more difference then that.
If you want to do a test, take a truck with instant read out.
At 60, shift down 2 gears if you have a 13 speed. Notice the difference.
Now speed up to 70 in 13th.
I absolutely guarantee you at 70 you will get much worse fuel mileage.
bob h 01-31-2008 09:32 AM
'As the truck speeds up from 60 to 70 mph', what causes the fuel efficiency to decrease?
I don't believe in the accuracy of your instant readout.
COLT 01-31-2008 12:36 PM
Wind resistance :wink:
