-   -   Should I Overhaul my N14 engine or trade it? (https://www.classadrivers.com/forum/truck-maintenance/32008-should-i-overhaul-my-n14-engine-trade.html)
solo379 01-26-2008 03:03 PM
Originally Posted by allan5oh
I'd say trade it.
2000 Freightshaker, with that many miles, worth nothing, in trade in value.
And 6.2 mpg, without knowing anything else, about job specifics, or driving stile, could be the best he will ever get.
I'm kinda on a Special K side! :)
Safari 01-27-2008 01:00 PM
I'd say trade it.
Solo379 what are you suggesting..? I would appreciate if you elaborate more. Thx
Bandit102 01-27-2008 01:41 PM
Cant believe anyone didn't mention the plastic piston cooling nozzles. N14 is well known for these breaking and dropping the oil pressure. Its a cheap, easy fix. Now, I'd definately roll a set of bearings in to it while I had the pan off.
I'd overhaul rather than trade. But that's just my .02 - its the way we do things. Keeps us out of truck payments and with todays rates, that's what we're after.
solo379 01-27-2008 02:00 PM
It's a business decision, and tho personally, i don't believe in investing in repairs more, than the truck is actually worth, it's not wise to suggest you anything, other than Special K already posted!
Cause we don't have enough info to do so! And 6.2 mpg is definitely not a deciding moment here.
After you'll check all the "easy" things suggested, and still will come to conclusion, that you need an overhaul, and after you gather all the "numbers$$$", including your personal financial situation, and general conditions of you truck, than you, and only you, will make a decision, cause there is no 100% warranty either way you go! Good luck! 8)
allan5oh 01-27-2008 02:27 PM
Sure it is.
What kind of operation is it safari?
Safari 01-29-2008 01:24 AM
Sure it is.
Bandit, Solo, and Allan thank you once again. Allan, we are OTR.
01-29-2008 01:54 AM
At 6.2 MPG with the newer trucks with all the emmison crap on them getting around 5.5 as long as you do not run CA overhaul it and keep it put an APU on it and that will let you run CA awhile longer also with a reflash of the ECM also. Why get rid of a truck that is getting 6.2 MPG and also saddle yourself with a payment on a newtruck is there anyother issues with the truck? I drove trucks that were not the newest but had the best maintance and they had fewer breakdowns than the newer ones that the companies refused to maintain.
allan5oh 01-29-2008 03:30 AM
OTR.. pulling what type of trailer, what part of the country, what kind of weights?
Safari 01-29-2008 03:02 PM
I pull 53 Reffer; we are based in MN and we follow the money! We dont have any particular lanes but mostly run from Midwest-South. Weights vary from light to 43K.
bob h 01-30-2008 11:56 PM
Re: Should I Overhaul my N14 engine or trade it?
Originally Posted by Safari
My 2000 freightliner truck, N14 Cummuns, has almost about a million
miles on it. Just recently it started to have very low oil presure like 20! should I overhaul it or trade it? I don't have any other major problems with the truck now, but my mechanic told me if I
overhaul cummins w/ 1 mill. on it, sometimes it leaks oil and
can't be repaired! If I decide to overhaul it
how much $ would it cost? any good advise and referrals would be appreciated.
Safari
N14 is one of the better h/d diesels ever built... as long as the rebuilder knows 'what' to look at during the overhaul, overhaul it !!
