-   -   overheating (https://www.classadrivers.com/forum/truck-maintenance/31570-overheating.html)
tankyanker 01-01-2008 07:02 AM
overheating
read a post about a driver who sprung a coolant leak and said the engine was "severely" overheated and damaged. had a similar experience about a month ago while pulling a load in east texas. burst a coolant hose coming out of a town on Hwy 84, at night, no shoulder to pull off on. ran the cat for about 20 minutes at 200 degrees, dummy light fading off and on intermittently, until i found a place to pull off and repair the problem. lost about 6 gallons of coolant.
how hot is too hot? what kind of damage does it do to the engine?
solo379 01-01-2008 07:55 AM
Re: overheating
I would not much worry, about that. A bit hot, but not "overheating"! :wink:
Kranky 01-01-2008 08:28 AM
Assuming the gauge was reading correctly, 200 degrees is not a problem.
The newer Cat engines in the fleet where I work run up to 210 before the engine fan kicks in.
I thought that was too hot, so I read the Cat literature and sure enough, thats the way it's supposed to operate.
allan5oh 01-01-2008 08:45 AM
The dummy light was on because of the low coolant, not the temperature.
