-   -   Tire sizes & rpm (https://www.classadrivers.com/forum/truck-maintenance/31493-tire-sizes-rpm.html)
Bandit102 12-27-2007 04:15 AM
Tire sizes & rpm
Anyone know if I'd drop any significant amount of rpm if I changed from 24.5 low pros to 11R24.5 tires? Right now, I turn 1600 at highway speed out west and would like to drop that as much as possible.
allan5oh 12-27-2007 05:13 AM
probably about 60 rpms.
Bandit102 12-27-2007 06:29 AM
hmm. not as much as I thought. Thanks Allan.
The rolling resistance is higher on the taller rubber, right?
I guess 60 rpm wouldn't make any notable difference in the fuel mileage anyway.
beeiatch 12-28-2007 01:46 AM
Re: Tire sizes & rpm
Go to Bridgestones website www.trucktires.com , it has a Q&A section that will help you with any question you might have. It is in "Ask the Tire Doctor" questions answered section.
Bandit102 12-28-2007 02:39 PM
Thanks, Bee.
tracer 01-08-2008 02:51 PM
you should look at the revs per mile of the new tire. the formula is; revs per mile times axle ratio times top gear ratio equals engine RPM at 60 mph. for example,
495 revs per mile X 3.73 X 0.73 = 1347 rpm
another useful formula is:
new tire diameter divided by old tire diameter is how much your RPM will change.
example: your current tire is 42 in; you switch to 40.7 in
42/40.7 = 1.0319; so your RPM at a given speed will increase by 1.0319
