-   -   pm's - engine hours versus miles? (https://www.classadrivers.com/forum/truck-maintenance/31126-pms-engine-hours-versus-miles.html)
eplurubus 12-08-2007 07:02 AM
Does anyone schedule their engine maintenance based upon hours instead of miles? I'm thinking about doing this. I have a Mack, and the operator's manual gives me the option of changing the oil every seven-hundred hours of use instead of going by miles driven. I'd still grease the truck using miles, though, since technically I could put hundreds of hours on the engine and not move the truck an inch.
When I was working for a farm or ranch, I'd use an hourly maintenance schedule on the farm tractors, but my service intervals weren't even close to seven-hundred hours! I'd grease every fifty hours and change the oil and filter every one hundred-fifty hours, with an air filter if needed, and I'd go few and far between on the fuel filters and hydraulic filters.
solo379 12-08-2007 08:49 AM
Re: pm's - engine hours versus miles?
I always do! I believe it's more appropriate, cause idling puts even more "dirt" in the oil. I also keep track of my miles, but just for informational purpose.
COLT 12-08-2007 09:46 AM
Before reading this board, I thought everybody went by hours....
500 hr's max, the new engines load the oil with soot, maybe less hour's on the new engines ?
I just shut my truck off, after 10 days, mostly idleing @ 1200 rpm, winter front almost closed off, running at 200 deg F ( very cold out ) heater MUST be on recirculate, not fresh, to keep engine temp. up.
When I go to the arctic, I belly tarp, the engine & trans. maybe 50 wt trans oil in the hubs too...
If I owned the truck, I would use synthetic oils, soo expensive for a big company to change over.... $$$$$
Kranky 12-09-2007 01:20 PM
I always changed oil & filters every 300 engine hours when I had my own dump trucks. (They were also Macks).
Complete grease job every 5 working days.
The company I work for now adheres to a similar schedule.
Oil & grease are cheaper than parts and much easier to install.
