-   -   Radiator Cap Question? (https://www.classadrivers.com/forum/truck-maintenance/30101-radiator-cap-question.html)
Papa Rick 10-07-2007 12:12 PM
On my Cat Motor C-15 475, I replaced the cap, but the old one did not have any numbers on it. The local parts guy told me that what he could look up it called for either a 10 lb or 15 lb pressure.
I asked him what difference it would make and he told me that if it was a 15 lb and I went to a 10 lb it might run hot since it wouldn't hold back pressure right.
He said that if it was a 10 lb and I put a 15 lb pressure on it there would be be no harm in this.
I bought the 15 lb to be sure. Both were the same cost so he was not selling me a higher price item.
What is your advice on this?
allan5oh 10-07-2007 12:14 PM
It won't run hotter, but it will boil sooner with a 10 lb vs. a 15 lb.
Of course you run a higher chance of blowing a hose with more pressure, but todays hoses are very well built.
You won't hurt a thing, unless you already have a leak.
Papa Rick 10-07-2007 12:18 PM
I guess the best way to find out would be to call a CAT Dealer wouldn't it?
number9 10-07-2007 01:54 PM
CAT dealer should be able to take your VIN and tell you exactly what it came with..... or someone here with the same setup.....
Part Time Dweller 10-08-2007 02:54 PM
Actually, since Cat didn't put the radiator or cap on the truck, a KW dealer would be a better choice. Just give them the last six digits of your S/N and they can look up the exact cap used on your application. No guessing involved.
number9 10-09-2007 03:56 AM
^ yeah, that's what I meant......
Part Time Dweller 10-10-2007 09:32 AM
Just checking. :lol:
bob h 10-10-2007 10:58 AM
it's true that cat didn't put the cap on, but they certainly DID tell them which one it was getting ; )
either should be able to give you an accurate answer
Fortes 07-28-2022 07:00 AM
Hello, if you are a Formula 1 fan, then this article has polls https://www.motorsport.com/f1/news/f...910621/910621/ but also a lot of fresh news, I think you should visit this site.
Rexx 12-19-2022 06:44 PM
Hello, its good
