-   -   Yet another problem................... (https://www.classadrivers.com/forum/truck-maintenance/29775-yet-another-problem.html)
marcel27208 09-22-2007 10:44 AM
Originally Posted by allan5oh
Is it an air leaking sound(clutch worn out) or a squeeling bearing sound(fan hub). They're separate pieces, at least on my truck they were.
Could just be your belt is loose.
In the morning, when you fire it up, the alternator load will be highest. It's just enough that it will only slip during the morning.
Fire it up for 20 seconds, turn it off, feel the pulley. If it's warm where the belt meets the pulley, it's slipping.
The reason it goes off when you hit the fan switch is because it puts a load on the belt, tightening against the pulley.
Just an idear.
sounds more like a squeaky bearing sound
bob h 09-22-2007 11:55 PM
fan solenoid
One 09-23-2007 12:56 AM
Your fan might be staying on constantly due to a faulty fan clutch or control device. If you had a bearing problem or a slipping belt, spraying water on the belt will make that evident by losing traction w/ the pulley.
marcel27208 09-23-2007 01:10 AM
is the solenoid something i can replace myself???? it sounds cheaper than the an clutch so id like to try that 1st
marcel27208 09-23-2007 02:50 AM
fan solenoid sint but about 30-40 dollars right?
09-23-2007 07:16 AM
Spark plugs are not gapped properly. Yup, that's it, I'm sure of it.
Mackman 09-23-2007 09:43 AM
:lol: :lol: :lol:
bob h 09-23-2007 11:03 AM
Your posts aren’t gapped far enough apart… that’s the current problem
marcel27208 09-24-2007 05:36 AM
ouch!
09-24-2007 06:09 AM
Originally Posted by marcel27208
ouch!
I know, Bob is so insensitive, he cut me to the core.
