BLOW BY
How much blow by is acceptable do you think, in your opinion?
I am looking at a dyno sheet for a truck I am looking at. The blow by is anywhere from .2 to 1.07. 2003 C-12. HP came in at 370 @ 1550 RPM. 37psi on the oil. |
Re: BLOW BY
I am looking at a dyno sheet for a truck I am looking at. The blow by is anywhere from .2 to 1.07. 2003 C-12. HP came in at 370 @ 1550 RPM. 37psi on the oil. i don't have the specs at home... why don't you ask the dyno tech, or service advisor, etc at the shop that run the test? |
| All times are GMT -12. The time now is 07:20 AM. |
