-   -   Turbo S pipe (https://www.classadrivers.com/forum/truck-maintenance/28231-turbo-s-pipe.html)
vontrial 07-13-2007 10:52 AM
Turbo S pipe
I have a det.60 series yr 2000, the (S pipe) that come from the turbo back to the flex pipe has burn loose from the turbo,call around find one for 116.00 will pickup tomorrow,from the looks of it doesn't look to hard to put on. Any advice will greatly appreciated. Trk is a Frtliner fld 120.
Thanks in advance
Vontrial
uncleal13 07-15-2007 06:49 PM
Nope. Pretty simple. The clamp on the turbo end is pretty straight forward. The clamp on the flex pipe end might self destruct when you try to get it off if it's rusty. New clamp there is only $15.00 . Oh, ya. The pyrometer thermo-couple will be on that pipe if your truck has one.
Blanket Party 07-15-2007 08:11 PM
Re: Turbo S pipe
Thanks in advance
Vontrial
Might as well go ahead and get the flex pipe while you're at it-they don't last forever, and it's alot easier to be done with it now, than later. Be sure to specify STAINLESS flex pipe and STAINLESS clamps, and a new flange clamp for the turbo to pipe mating area.
