"no faults found" |
ok good........ but my engine protection light will faintly come on every so often... it has done it 2-3 times this past week....its not lit up all the way its kinda just faintly on and it will bounce on and off for about 10 minutes then not do it anymore!??? may it be a sensor or something loose???
also, check for teflon tape on the retaining bolt threads of one of the forward side (large) ecm connectors |
is the ECM located around the coolant resevoir on my engine?
some of the connectors are secured by snap-type locks, others are held in by a bolt at the center of the connector body take a look at the seals around the back of the connector before you remove the connector |
If the light is flickering dimly, as in getting intermittently grounded, and no codes are showing, I would not look at connectors for a loose connection, rather I would look at rubbing points of the harness for an intermittent ground...it can be a real PITA to find these things
Birken |
now its flashing on chk engine light code '62'...whats that code mean???
