trans fluid to clean injectors
i was reading somewhere on here that filling fuel filter with trans fluid will clean injectors??.and or also putting trans fluid in fuel tanks occassionally.. will this help, hurt ??
Re: trans fluid to clean injectors
standyne or howes |
There are those here who swear by it. I wouldn't do it, though. It isn't designed to be run through injectors. |
And don't forget your starter fluid in case you get a flat tire-Be Veeeery careful though-Some people tend to over do it and then you just defeat the purpose :P
It'll get you down the road in a Pinch |
It's an old school trick-If you get a Flat(Not a blowout) you spray the Starting fluid around the bead and throw a match at it-It'll give you some inflation of the tire and get you to where you can can your tired fixed.
Main thing wrong with the trans fluid is some of it is RED, this WILL make it look like you are running "dyed" fuel........big NO NO!!!
Not worth the trouble........Power Service or Howes. |
:P I've seen those tire guys who are up in the years with red burned up faces. :P |
It works but you gotta be careful doing it-Only did it if I had to-Don't over do it with the starter fluid and if you're pulling a Tanker I wouldn't advise it :P
You worry too much M....lol |
