-   -   park brake (https://www.classadrivers.com/forum/truck-maintenance/24369-park-brake.html)
heavyhaulerss 01-29-2007 02:08 PM
park brake
NEED SOME HELP HERE. WHEN I DO MY BRAKE CHECK, MY PARK BRAKE (RED & YELLOW BUTTONS ) DO NOT POP OUT UNTIL AIR GAUGE'S BOTTOMS OUT. I HAVE REPLACED THE PARK BRAKE WITH A NEW ONE. THERE IS NO DIFFERENCE, IT WILL NOT POP OUT BETWEEN 15 & 40 LBS LIKE SUPPOSED TO. ANY IDEAS ? THANK YOU. TROY
Jackrabbit379 01-29-2007 02:11 PM
Well,they are supposed to. When that air pressure drops to that point,the breaks set. They do that so that there is enough air to set the breaks for safety reasons. I'm not a diesel monkeynick,but that is the best that I can come up with. :P
....::EDITED::... :shock: :?
Sorry,I totally misread that. I am sorry,I thought that you wrote that your red,and yeller knobs DO pop out. Maybe a senser that tells them to pop out,isnt working? I'm sorry,not much help. :? Hope ya get r fixed.
bob h 01-30-2007 10:40 AM
Re: park brake
if your pressure gauges are correct..., install a new dash (push-pull) valve
heavyhaulerss 01-31-2007 03:07 AM
THE NEW DASH PUSH PULL BRAKE IS WHAT I WAS REFERING TO AS PARK BRAKE. I DID INSTALL NEW ONE. SAME RESULTS. HOWEVER I HAVE NOT REPLACED THE AIR GAUGES. THEY SEEM TO WORK?? IS IT POSSIBLE THEY CAN LOSE ACCURACY ?
bob h 01-31-2007 03:23 AM
yes, but surely not simultaneously
bob h 01-31-2007 03:44 AM
on your keyboard; look to the far left, above the "shift" key and below the "Tab" key, the button is labelled "Caps Lock". press that key once
thank you,
p.s. - when you type with all caps it indiCATES THAT YOU ARE YELLING AT ME!!!
and......... my last nerve is already hanging on by a thin thread ;0)
heavyhaulerss 01-31-2007 05:44 PM
thanks for the response bob. didnt mean to yell. i must have caught that from my wife . lol
bob h 01-31-2007 11:57 PM
L O L !
JoeyB 02-01-2007 12:45 PM
I've seen that happen in other trucks as well. I think the forces (air pressure vs spring pressure) balancing that valve are so low by the time you're down to 45 psi, any O ring that has a little too much drag is enough to hang it up. The only thing I could suggest is to try to dribble a little air-tool oil into the valve to lube the o ring that seals the knob shaft.
heavyhaulerss 02-01-2007 03:02 PM
hey now get this.. ready?.. here goes... when i do my brake check engine off & key on the buzzer & light work just like supposed to. the brake valves do not pop out until the air gauge bottoms out. maybe 2-5 lbs at most.. but... but... if i do brake check with engine running the valves pop out between 25- 40. tried 12 times. pops out every time. i just pump brakes faster than my ole won out compressor can replenish & out they pop. let it build back up & pump down again & pops out just like it supposed to.. one more thing.. is this type a problem a shut down offense if a had to do a full insp at scale with the d.o.t ? thank you. i know bob will have imput here.. :lol:
Birken Vogt 02-01-2007 04:14 PM
As far as I know the yellow valve does not really have to pop until basically 0 psi and many trucks are set up this way. The reason being you want to have manual control of your tractor brakes as long as possible in an emergency situation and not have a "dynamiter" where the spring brakes all set up simultaneously. Which could definitely cause loss of control if you are still trying to get the thing under control while moving at a pretty good clip. This is not loss of a safety feature as the spring brakes will still come on gradually as the pressure drops below 40 psi or so anyway but you want them to stay off as long as possible to give you every chance you've got to fix whatever is wrong yourself.
Now the red valve on the other hand, is supposed to pop somewhere between 45 and 60 IIRC, too lazy to look it up right now, but always well before the yellow knob does to close the tractor protection valve and stop catastrophic air loss through the trailer.
And of course many yellow knobs will pop at pressures substantially higher than zero, there are 10psi, 20 psi, 40 psi, and even higher available, it all depends what you buy and install.
Birken
JoeyB 02-02-2007 09:35 AM
No, they must BOTH pop at 45-20, although not necessarily at the same time. As far as their poping with the engine running, that gets back to what I said earlier. Just a hair too much internal drag in the valve and no dice. But add the slightest vibration to the equation and presto!
Don't know for sure, but I'd guess that as long as you can get them both to pop, even if it's near zero, you're good to go with the DOT. The only reason I say that is because if it were any other way, half the trucks in the country would be O/S.
bob h 02-02-2007 12:04 PM
i agree with birken here; the tractor protection valve (breakaway valve) shuts off air supply to the trailer in the event of trailer air system failure, and stops it from depleting the tractor air tanks
red button should pop well before the yellow
Birken Vogt 02-02-2007 03:02 PM
State your source
Birken
heavyhaulerss 02-04-2007 03:10 AM
bob & all the rest.. i really appreciate all your time & input here. i over a short time i put in a new dash valve. then i got a used one. then last week another new one. all have performed the same. somehwere around 5 lbs before poping out. they both pop out at same time every time. i guess this is one of those things that keeps ya scratching your head..
JoeyB 02-07-2007 12:28 PM
State your source
Birken
Federal Motor Carrier Safety Regulations 393.43 (b) ..."One of these means shall operate automatically in the event of reduction of the towing vehicle air supply to a fixed pressure which shall not be lower than 20 pounds per square inch nor higher than 45 pounds per square inch"...
Trailers will usually pop before the red knob does; that's the trailer's relay emergency valve response to the lowered supply pressure from the red gladhand. The trailer does this on it's own. If you keep fanning off air, usually the trailer supply knob will pop next, and then the yellow one.
heavyhaulerss 02-07-2007 04:04 PM
thank you joey...
Birken Vogt 02-07-2007 04:14 PM
Not trying to be a lawyer here, but 393.43(b) applies to trailer brakes only. There is no reference to the tractor emergency/park system at all.
Right or wrong, the trend for the yellow knob on newer trucks has been for it to pop just above zero PSI, or not at all due to o-ring drag, in order to give the driver the most chance possible to control the vehicle manually. In the event of catastrophic loss of air the spring brakes will come on anyway so what's the difference.
393.43(b) Emergency brake requirements, air brakes. Every truck or truck tractor equipped with air brakes, when used for towing other vehicles equipped with air brakes, shall be equipped with two means of activating the emergency features of the trailer brakes. One of these means shall operate automatically in the event of reduction of the towing vehicle air supply to a fixed pressure which shall not be lower than 20 pounds per square inch nor higher than 45 pounds per square inch. The other means shall be a manually controlled device readily operable by a person seated in the driving seat. Its emergency position or method of operation shall be clearly indicated. In no instance may the manual means be so arranged as to permit its use to prevent operation of the automatic means. The automatic and manual means required by this section may be, but are not required to be, separate.
heavyhaulerss 02-07-2007 04:17 PM
thank you birken
bob h 02-07-2007 11:35 PM
quote="JoeyB"]
State your source
Birken
there is no trailer valve that causes the red button to pop off. the valve pops off based on line pressure ; when pressure over the piston of the red pp valve is reduced to 20psi (20 to 45) the spring force under the piston pushes it out. that dumps emergency line pressure and then closes the tractor protection valve to isolate the trailer air system from the tractor
the tractor controls the air supply and service function to the trailer, the trailer only reacts to what it is told by the tractor
If you keep fanning off air, usually the trailer supply knob will pop next, and then the yellow one.[/quote
agreed
JoeyB 02-08-2007 10:13 AM
Originally Posted by bob h
quote="JoeyB"]
State your source
Birken
agreed
Read what I have written again- that's what I'm saying, bob. The trailer goes into emergency on it's own without any action from the tractor OTHER THAN low pressure in the supply line.
JoeyB 02-08-2007 10:51 AM
All right, Mr. Lawyer... I read that thing again and I see what you're saying. That's talking about the red knob, we're talking about the yellow knob. I used to have a copy of the ATA recommended practice, I'll be able to get my hands on it saturday. We'll see if that sheds any light, I'm sure they detailed an air brake test.
All of our texts at the school says both valves pop 45-20, and that's how we taught it, and that's usually how it worked.
Birken Vogt 02-08-2007 04:02 PM
Most any training material will say 20-65 psi or thereabouts for yellow knob pop-out but they do that to cover all the years, makes and models from the brand new to the ancient. However I am just saying from experience and from the Bendix air brake class put on by Paul Jones, that on newer trucks sometimes the valve will not pop out until the system is almost at zero pressure. This is a good thing because the driver can still pull that knob whenever he wants to and it is better for him to retain manual control over the brakes of the truck than to have it come on all at once (a "dynamiter") if it can be avoided.
Also if system pressure drops below about 20 psi or so the spring brakes will be on pretty much full anyway so it doesn't really matter whether the yellow knob is out or in at that point.
Finally does anyone remember the old Ford C-series trucks with the modified TW (flipper style) valve for the parking brake? These were made into the 1990s and had no provision whatsoever for automatically changing the position of the valve based on air pressure; the valve could be moved into either position even with no air whatsoever in any tank. I actually liked those
Birken
bob h 02-09-2007 12:49 AM
this applies to mv-2, mv-3, and midland kn20615 tractor dash valve systems ;
quote* "Loss of pressure in both systems- if pressure in the highest system is lowered between approximately 35 and 45 psi, the trailer air supply valve (red button) will "pop", causing the trailer spring brakes to apply. If pressure continues to drop so that pressure in the highest system is between approximately 20 and 30 psi the park brake control (yellow button) will "pop", causing the tractor spring brakes to apply." *unquote
i don't necessarily agree with this entirely, but what kind of valve do you have?
heavyhaulerss 02-09-2007 01:29 AM
as far as myself.. i have the red/ yellow dash knobs.
Birken Vogt 02-09-2007 05:35 PM
Well one I know for a fact of the top of my head doesn't really pop until basically zero PSI is a Bendix PP-DC which is like half a MV-3. If I recall correctly the regular PP valves (PP-1?) are available with all sorts of different springs including no spring at all.
I have not seen a Midland or Meritor valve that did not have a pretty hefty spring in it though.
Birken
bob h 02-12-2007 12:07 AM
Birken
pp-dc is a tractor park valve, and is designed to pop off at 20-30 psi
i believe that the pp- 1, 2, 3, 5, 7, and 8 all have different pop off settings
Birken Vogt 02-12-2007 02:31 PM
The pp-1, 2, 3, etc. are all different designs of valves for different applications, models if you will with different ports and functions. They could all have the same pop pressure if ordered that way, the number is a model number and not anything to do with pressures, etc. The pp-1 is the most common for tractor parking (or at least the "classic") and is available with many different springs for different pop pressures, or no spring at all.
Birken
RockyMtnProDriver 02-12-2007 03:37 PM
The purpose for a dash valve to pop out (dynamite) is as follows.
If you lose your air pressure, then at some point your spring brakes will start to drag. That is usually around 60 to 70 psi (and that is of course why your governor MUST start to reload at a minimum of 80 psi).
If you get down to 10 psi and the yellow dash valve has NOT popped out, then in the event that you forget to pull it and start the truck up, and walk away from it, then it could very possibly roll away once it has built up enough pressure to release the brakes.
That is why they got rid of manual dash valves.
In BC, which has the same rules as all other jurisdictions in North America, if your Yellow (tractor) or Red (trailer) dash valves do not pop out by 20 psi, it is an out of service defect, and you will be parked.
heavyhaulerss 02-12-2007 06:54 PM
o.k rky mountn.. now.. that makes sense.. t.y.
JoeyB 02-13-2007 10:18 AM
Well I got hold of a copy of a Recomended Practices Manual (The Maintenance and Technology Council of the ATA), but it's from 2000-2001. RP 619A titled "Air System Inspection Procedure" goes into great detail with regard to testing the air system on the entire rig. They do look for the 45-20 on the tractor protection valve (the red one), but on that one there's no argument. As for the Tractor Parking valve, they just say to verify that the spring brakes apply when you pull it out and release when you push it in. There's not a word about any specific pressure.
Personally, I like Rocky's explanation. That makes perfect sense and dovetails with the idea of it's staying in as long as possible to keep control with the driver.
RockyMtnProDriver 02-13-2007 02:06 PM
One of my buddies is a Commercial Vehicle Inspector for the BC government and the next time I talk to him I am going to get the straight goods from him as to what the law says.
bob h 02-14-2007 12:16 PM
inspection criteria here says that the trailer valve must pop by 20 psi, they seem to be referring to the tractor protection valve, but they do specify that the button should pop before 20 psi... there was no reference to the tractor park valve at all
... i tried an fld today, the red popped at 45 psi, the yellow at just above zero
RockyMtnProDriver 02-14-2007 01:41 PM
For those that want it here is how a tractor protection system works.
The tractor protection control valve (red dash valve) when pushed in (on modern trucks, some older systems had them pull out to supply air) sends air to the supply side (usually red air line out of the back of the tractor) through the tractor protection valve.
Air is also directed inside the tractor protection valve to the bottom of a sliding valve. As this valve is pushed up it allows air to transfer from the service side (foot valve) to the service line going to the trailer (usually a blue line) when a brake application is made with either the foot valve or hand valve.
When the supply line is disconnected, or ruptured, and enough air is lost, then there is not enough air to hold up the sliding valve and it is forced down by a spring.
Once this happens, the tractor protection control valve (red dash valve) then pops out as there is not enough air to hold it in.
And because it has slid down, it seals up the service side and no air can travel from the foot valve to the trailer on the service side.
When you break a service line (control line) nothing will happen until you make a brake application.
Then you have air loss, and when enough air is lost the trailer brakes will dynamite. If you have spring brakes on the trailer, the spring brakes come on as air is evacuated from the spring chamber. If you have service brakes, air is blown into the service chamber to make the brakes come on immediately. This is where the term dynamite comes from. once it gets to the appropriate air pressure (45 to 20) the tractor protection system activates and the air is shut off at the red dash valve.
There is a tractor protection system where the brakes will dynamite immediately upon the rupture of the service line. This is more common in older logging trucks, although some are still built this way.
When you break a supply line, the trailer dynamites the moment the trailer relay valve (spring or service) senses air loss, and once you get to the appropriate air pressure (45 to 20) the tractor protection system activates and air is shut off at the red dash valve.
Of course, if your trailer dynamites while you are driving at speed, then you either will skid your tires in the summer, or in the winter the trailer will try and pass your tractor.
Now, more than likely if you break both of the lines, it is because your trailer is no longer attached to your tractor.
And you have larger problems than broken air lines.
RockyMtnProDriver 02-15-2007 11:31 AM
I talked today to my buddy from the CVI. He checked and it appears that there is NO regulation that a tractor spring brake dash valve has to pop out at any PSI whatsoever.
They use to, but for some reason, they do not need to anymore. I think this is where I confused old regs and new regulations.
He was unsure if there is specification that manufacturers have to meet when they are brand new.
He was quite surprised to find that out.
He said that Trailer valves MUST pop out no lower than 20, and can range as high as 45 in the regulations, but many come out much higher than that.
All jurisdictions on North America comply to the same regulation, so it must be the same in Canada, USA, and Mexico.
He said he was going to dig a bit deeper as it surprises him especially taking into accout that someone could walk away from a tractor with the dash valve in, not enough air in the tanks to release the springs and if the engine was running when it built up enough air it could roll away.
It does not seem like a very safe thing to him. Or me, for that matter.
